XS650 ignition coil
slash
This post is 5623 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I'm having a problem with the coil on my 650. It has a Lucas rita ignition box, single magnetic
pickup and a single dual fire coil. The coil i originally chose is one off a VF1000r, dual fire with replaceable
leads but the main reason was the plug leads exited on the side of the coil not bottom.
The coils ain't lasting plus their getting harder to find, so i used an automotive coil from a V6 buick.
It uses 3 coils all dual fire plus their a dime a dozen. The coil lasted about 10 minutes before packing
it in. I assume the new coil is a low ohm and the lucas system, being old tec is high ohm.
My question is can i resistor or something the coil outputs on the lucas system to get it
to work with the low ohm coils? :rolleyes:
mikesxs do coils that should be right for you bike
http://mikesxs.com/
merv
