float height for ybr 125
Morgy
This post is 5648 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
HI Morgy
The float height for the 05 YBR125 is 21.8mm measured from the float bowl gasket face (i.e gasket removed} to the bottom of the float. Also when checking make sure the tang of the float just touches the needle valve and doesn,t compress the spring inside the valve. Hope this helps. Tony.
HI Morgy
cheers Tony this helps alot, the more info the better, thanks again :thumb:
Hi Morgy
Just noticed in the manual they also list a fuel level of 6 to 7mm checked by connecting a piece of clear tube to the float bowl drain and undoing the float bowl drain screw with the fuel tap on and holding the tube next to the carb. The distance is measured from the horizontal line of the carb / floatbowl join to 6 to 7mm below the line with the bike level and upright. This is probably easier to check then having to take the carb off to check float height.Hope this helps.Tony.
