0-60mph?
Goldtop57
This post is 5702 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi, I am new and I am looking at buying a new Yamaha YZF R125. Does anyone know roughly how fast it gets to 60? I have only ever had 2 stroke 125 bikes and am a little unsure of the 4 stroke. It is the best looking 125 I have ever seen though! I am not too bothered about the top speed, as long as it does about 80+ ish which I undersatnd they do! I prefer acceleration! any info would be great..
Found this, on Google for you.
from, Topspeed.com (so i dont get sued)
New price £2,999
Engine size 124cc
Power 14.6bhp
Top speed 75mph
Insurance group 6
For 2008 Yamaha will launch the all-new YZF-R125, an exciting new member of the R-series family which is aimed at taking the number one position in the sports 125cc market.
Featuring a liquid-cooled single-cylinder engine running in full-sized Deltabox chassis – and clothed in aggressive R-series style bodywork – the YZF-R125 is aimed at the young first-time 125 buyer who demands best-in-class engine and handling performance, and winning R-series style.
Engine
Yamaha’s first liquid-cooled 125cc 4-stroke 4-valve single
The R125’s all-new 124cc 4-stroke engine is the most advanced in the category, and just like its larger-capacity R-series brothers, it has been developed to deliver class-leading performance.
In order to achieve this goal, Yamaha’s engineers have created the company’s first ever liquidcooled 4-stroke single-cylinder 125cc SOHC engine. The new R125 benefits from a 4-valve cylinder head which delivers high levels of intake and exhaust efficiency for ultra-responsive performance.
Fuel injection
For instant throttle response, this new high-tech 125 features a compact fuel injection system fed by a large-capacity airbox which, combined with the two inlet valves, delivers optimum intake efficiency together with excellent throttle response across the rev range.
Free-revving short-stroke engine
Featuring bore and stroke dimensions of 52mm x 58.6mm, the compact short-stroke engine has a free-revving character which enables it to deliver strong acceleration. This short stroke layout – combined with the performance-boosting qualities of the 4-valve head, fuel injection system and free-flowing exhaust – gives the R125 the strongest overall performance in the 125 4-stroke class.
R6-style mid-ship muffler
Performance is also enhanced by the fitment of a free-flowing large-capacity R6-style mid-ship muffler, whose location helps to centralise mass for neutral handling performance. The exhaust system accommodates dual catalysers, as well as an air induction system which introduces air into the exhaust to enable more complete combustion of any unburnt gases, and in doing so it helps to reduce emissions to even lower levels.
6-speed transmission
To optimise the class-leading performance characteristics of its all-new high-tech 125cc liquidcooled engine, the R125 is equipped with a 6-speed transmission which ensures strong acceleration and a competitive top speed.
Technical highlights
Liquid-cooled single-cylinder 4-stroke
SOHC 4-valve cylinder head
Wet-sump lubrication system
Fuel injection
Electric start
Dual catalysers
Air Induction system
Chassis
Full-sized chassis with Deltabox frame
Just like its larger R-series brothers, the new R125 features a lightweight Deltabox frame which delivers an optimum balance of strength and rigidity for class-leading handling performance. The twin spar Deltabox design has proved to be one of the lightest and best-handling frame designs in the supersport category, and its use on the new YZF-R125 underlines Yamaha’s total commitment to building the best-handling machine in the class.
One of the most significant features of the new R125 is that it has been constructed with a fullsized chassis, which is unique in its segment. For example, the wheelbase on the new Yamaha R-series is 1,353mm, over 58mm greater than a typical sports 125, which helps to enhance stability.
The larger physical size of the machine also allows our designers more freedom in creating a sporty yet comfortable riding position. And finally, the larger chassis gives the machine far greater presence on the street.
Aggressively-styled full-sized supersport bodywork
With its unmistakeable R-series styling, the R125 stands out in the crowd, and is easy to mistake for a much larger capacity machine. The dual headlights have a distinctive R-series look, while the low frontal area and small tail are clearly influenced by the bigger R-series bikes. And like the chassis, the bodywork is full-sized, making this new sportsbike the most impressive looking machines in the class.
Aluminium swinging arm
Complementing the race-bred Deltabox frame is a cast aluminium swinging arm. By keeping unsprung weight low, this high quality swinging arm allows the link-type rear suspension system to operate more efficiently and deliver more responsive handling qualities.
33mm diameter front forks
Equipped with large-diameter 33mm tubes, the smooth-action front forks are designed to deliver accurate steering together with good rider comfort. For easy manoeuvrability this high quality front suspension system features a steering angle of 24.2degrees and trail of 86.1mm. And with 130mm of wheel travel – over 20mm more than some other models in the class – the full-sized forks on the new R125 perfectly complement the Deltabox frame and aluminium swinging arm to deliver stable yet responsive handling.
Large diameter front disc
High build quality is evident wherever you look on the new R125, and the front braking system is another example of Yamaha’s commitment to using only high-specification components.
The large diameter 292mm front disc is slowed by a compact twin-pot caliper which delivers strong and progressive braking performance for good controllability over a wide range of speeds. The large single front disc is complemented by a 230mm rear disc, giving the R125 rider accurate control in town as well as on the open road.
Lightweight alloy wheels with wide-section tyres
As well as ensuring that the unsprung weight is minimised in order to enhance the front and rear suspension performance, the distinctive 10-spoke alloy wheels give the R125 a unique look.
The lightweight wheels are fitted with some of the widest rubber in the class, with a 100/80-17 tyre at the front, and a massive 130/70-17 tyre at the rear, which ensure high levels of traction and underline the YZF-R125’s position as the main contender in the sports 125 class for 2008.
Range of quality accessories
Yamaha have developed a range of quality accessories for YZF-R125 owners wishing to customise their bike. The line-up includes a double bubble screen, a yoke, a seat cover, roller protectors and a tank pad.
Lightweight steel Deltabox frame
Cast aluminium swinging arm
Aggressive R-series styling
High quality components
Leading build quality
Full-sized chassis and bodywork
1,355mm wheelbase
Sports riding position
Dual R-series style headlamps
292mm diameter front disc brake
230mm diameter rear disc brake
Ultra-compact tail cowl
Compact LED tail light
130mm front wheel suspension travel
130/70-17 rear tyre; 100/80-17 front tyre
Range of accessories:
Double bubble screen
Seat cover
Carbon yoke protector
Roller protectors
Tank pad
Available colours
Burning Blue
Sports White
Impact Yellow
Midnight black
Specifications
Engine
Engine type: Liquid-cooled, 4-stroke, 4-valve, single cylinder, SOHC
Displacement: 124.66 cc
Bore x stroke: 52.0 x 58.6 mm
Compression ratio: 11.2:1
Maximum power: 11.0 kW (15 PS) @ 9,000 rpm
Maximum torque: 12.24 Nm (1,25 kg-m) @ 8,000 rpm
Lubrication system: Wet sump
Fuel System: Fuel injection
Clutch type: Wet, multiple-disc coil spring
Ignition system: TCI
Starter system: Electric
Transmission system: Constant mesh, 6-speed
Final transmission: Chain
Fuel tank capacity: 13.8 L
Oil tank capacity: 1.15 L
Chassis
Chassis: Steel Deltabox
Front suspension system: Telescopic forks
Front travel: 130 mm
Rear suspension system: Swingarm (monocross)
Rear travel: 125 mm
Front brake: Single disc, Ø 292 mm
Rear brake: Single disc, Ø 230 mm
Front tyre: 100/80-17 M/C
Rear tyre: 130/70-17 M/C
Dimensions
Length: 2,015 mm
Width: 660 mm
Height: 970 mm
Seat height: 818 mm
Wheel base: 1,355 mm
Minimum ground clearance: 155 mm
Dry weight: 126.5 kg
New price £2,999
Engine size 124cc
Power 14.6bhp
Top speed 75mph
Insurance group 6
Engine
Fuel injection
Fuel injection
Electric start
Dual catalysers
Chassis
1,355mm wheelbase
Seat cover
Roller protectors
Tank pad
Available colours
Burning Blue
Sports White
Impact Yellow
Midnight black
Specifications
Engine
Chassis
Rear travel: 125 mm
Dimensions
Length: 2,015 mm
Width: 660 mm
Height: 970 mm
Seat height: 818 mm
Yeah I have seen a lot of info like this and it does give a good description but no one seems to know what the 0-60 is! I went into a Yamaha dealer and asked and they didn't know! Hopefully someone who owns one will let us know!
Has anyone fitted a power commander yet? I know Dynojet have one. Any Good?
