XJ750?? frame 1981
Tigerback
This post is 5712 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi, My son has just bought a yamaha XJ750 trike and managed to hit a wall bending the bikes frame (just under fuel tank.
Since its a trike we are not sure which model xj750 it is as the log book just says trike.
can anyone tell us , if the frames on all the xj750's are the same? or do they all have different ones.
the bike is a 1981 and it seems for the next 5 years there are many XJ750's but they have letters after the number and look different fuel tanks and seats.
Any help would be apprciated.
In most manuals you'll find a section on identification numbers (usually at the front), this section will tell you which letters or numbers will tell you what model & year that particular bike is from. Alternatively write down the frame number (complete) & ask a maindealer.
I would've thought so, considering the mass production & where the engine mounts would be. Then the same engine configuration (tuned however) should fit a variety of frames.
Just like the early xj/fz600 engines that interfitted each other & also fitted into a xj550 frame, i had a xj550 like this & boy did it shift.
Thank for all your help, managed to find info i needed, if anyone is intrested heres the details i obtained:-
XJ750J
XJ750K
XJ750MK theses 3 are classed as a MAXIM and all have the same frame/part No 22R-21110-00-98
XJ750RH
XJ750RJ
XJ750RK these 3 are classed as SECA and have frame/part No 5G2-21110-10-33
the frames are both Very similar as they have same engines but mountings for seats/side panals are different.
again thx for help Dan :D
