1978 DT175E Oil Pump
What is this seafoam you speak of?
Im selling the Jawa
That was why then
xv 125 jetting probem
Hi Paul..Why do you want to re jet? are you talking of the Sach or the baby drag?
1979 DT 250 Carb
A picture would help, see FAQ's for pics. The pilot screw on these 2 strokes is normally an air screw and sutuated towards the back of the carb, not the front.
DT175 G (1980) Seizure
Hi Johnny, welcome to the forum. The bike looks great for its age, a bit of a sickener this happened twice. have a read of this post Here for and idea how to pressure test your engine. I would also advise a bit of plug chopping to see whats going on here. From experience I find that the inlet manifolds dont seal well against the reed cage due to the in-built o-ring becoming flattened, they need a little extra help using a bead of silicone gasket sealer at this point, also they can split on the underside so have a visual inspaction here. What sort of trim is the bike in, is it totally standard with a good air filter fitted clean and oiled? ...Paul
Identifying a motorbike. (Picture included)
looks like a boat anchor, must therefore be a Jawa.
New Member - 1979 DT 175 not revving past 6k
Youre checking the wrong place, its not at the CDI connections its the four way multi connector from the magneto, a white plastic connector that would be the place to check, in fact it will be the same place you checked the spare magneto.
No its not ok, the specs have been given earlier. You are checking the connector that goes back to the magneto arent you?
gpt my other bike ready
Dont do it Darren, I've seen these antics on U Tube...they end in tears...
A cheap way to 'de girl' my YZF?
...or try your local signwriters, they can make you some vinyl graphics to stick over the pink ones...
OldGit's Rideout...
Thats whats puzzling me too
who are we all
I’m Paul and I’m 31 years old, I know some of you lot think I’m older than that but actually I’ve been living a bit of a lie, you see I only chose that silly user name moniker so that I could join in Blackhat250’s posts about Garelli mopeds, my dad used to go on about those things all the time so I just learned about them through listening to him, I just thought It would do no harm and at the time it made me feel that I actually knew something about motorbikes…anyway, sorry guys, hope youre not mad with me… Paul
Hello .I'm new here and here's a question.......
Oh yeah!!!
Look what i got!
Ahem! You know I hate to have to tell you this Goff... But I think youve been sold a pup there...
A plea!
Ive done exactly that before but used a slice of aluminium cut from a beer can...needs must....worked ok for a while too. Steve youre gonna have to make a good job of it mate, DONT be late for the RAF
Can you count - He can't!!
Ha...Bet he felt a right two after that... :
OldGit's Rideout...
Bloody hell Tt, it doesnt get funnier each time its told does it? ...
Look what i got!
Its all head! ...hows Marvin with her? I dunno is Marvin still with you? I used to have a Rott caled Dolcie...
Need help with 1982 400. Intro.
Hi, not familiar with model but does it have a side stand switch? If so, disconnect it and short out the connectors with a piece of wire and try again, or check the switch with a multi meter. ...Paul
- squires
DT125R 2002 Overheating
Hi Andus...Looks like you forgot to check the thermostat.. I dont know the bike but there will be a thermostat, this is closed when cold and opens up when hot to allow water flow to the radiator. The old way of ckecking them used to be to immerse them in a pan of water on the stove and witness them open up when the water gets hot. also they sometimes have the operating temperature stamped on them somewhere. so you can use a thermometer to check they work at this temperature. If its no good you may be able to run the bike without it until you get a new one. ...Paul
Hi all, newbie with pics!
Welcome to the forum Dan...Bloody gorgeous bike you've got there... ...Paul
Well...looks like weve a budding talent amongst us..
A big thank you to Oldgitonabike
Hey, thanks for the big up DirtyDT..its always good to meet other forum members, glad i could help with your project...
DT175MX piston/bore clearance
Hi Phil, It does sound like the piston is a bit small then, however they are in fact tapered so you must measure at the bottom (skirt), I know you say you did but... The only other way is to get a micrometer and a bore gauge to check one against the other.
