The Dukes pass
Havr you eaten blackhat250 ? ...
The Dukes pass
Yamaha SR125 Starting problem
you may find that if you cover the hole where you think the screw is missing with your finger when its revving crazy, the revs will drop right down, this would rather conferm your suspicions.
- Foamy goes touring
plastic coating???
dunno, how about a hot air gun and wire brush? easy on the brush if theyre ally though...
Manchester Riders
And me...
Don't you just love tools??
Boys and their toys eh Looks like a spot blaster, you need to remove the big plastic nozzle and collection bag now, heres mine with them removed. then get some kiln dried sand from your builders merchants and run a tube into the sand instead of the on board container (for large items)
I am New Here
Hi BillyO welcome to the forum... ...Paul
:S pig sick
Dont worry, if anything comes of it tell them about the wasp that just flew ito your open visor or jacket etc..
1973 250 MX
Get yourself a manual and test the stator coil against spec and also ignition HT coil...
New to Forum - Always on Yams
Welcome to the forum UncleSol...
xvs 125 restriction rings. (fecked)
From experience I would not advise you to try to drill out sawed off studs, Its a bloody minefield trying to do by hand and a head off job to do otherwise, better to dremmel the nuts off somehow and then remove the studs after heating with a blowlamp....BUT personally although I dont know for sure I'll admit, but I doubt if the baby drag has restrictors as it wont be a powerful engine to start with so would all be just a waste of time if that's the case.
77 yz 250
Dont forget to open throttle wide when compression testing.
i need help on a yamaha dtr 125 question plzz
2001 ones will fit
Accessories for old bike
Aahh!! the wonders of Google
try a spray of the HT lead and plug cap with WD40 as well.
- Hellooooo
hammer attack on my Genesis.
Cant say for sure but I doubt it will go over yours. Why not do a pressure test on the new tank to check for leaks?
Electrical problems with my lights
Hi Freaser, perhaps This might help ...Paul
1975 yamaha dt 175 headlight buld
These are the ones for the MX models, dunno if yours is the same, theyre American pre focus types Here you can select different wattages / voltages on the drop down. ...Paul
xv 125 jetting probem
what is a sachs roadster? two stroke, four stroke, twin, single?
Mirror repair
Why not put a photo of an R1 in the mirrors and pretend youre really going fast...
1978 DT175E Oil Pump
A bit like Sanatogen for bikes then
DT125 Engine issues
Hi...you left the side stand down or if you didnt, check the plunger on the switch isnt stuck in, give it a spray with WD40 and get it free, if this doesnt work unplug the wires and short them out to each other and fit a new switch later if this cures it. ...Paul
1979 DT 250 Carb
Never seen a carb like that myself, looks like its got two mixture screws. The filter side being an air adjustment, in to richen and out to lean. And the engine side being a fuel adjustment, out to richen and in to lean. Just a guess!
