Airhead
  1. In the short term squirt some 2 stroke oil in the spark plug hole. Then try bump starting it. If you get it running and still continue to get 70psi compression you will have to strip the top end and check the ring end gaps, it may need new rings. It may even need a re-bore.
  2. Welding a handle to a couple of plain plates is one way to do it but like you say it leaves you wanting more plates. Another 'Bling' way is to buy one of these if you can find one, this is mine for a DT175MX (DT175E in USA) However the cheapest way is to make one of these from some 1/4" flat bar This was a method as shown in my Haynes manual and the one I used to use before the 'Bling' one. Here is a clip from said Haynes manual ...Paul
  3. It's the one I use for all the pics I post on here Vez, a Kodak CX7300 digital camera, takes great pics.
  4. Yep, and just love the sound it makes
  5. There are also garages for motorcycles that do not have fancy showrooms to sell new bikes, you know the 'under the railway arches' type of place. i expect that these would be far cheaper than franchised dealers. In the end ask around, get quotes from both types of place. talk to the guys and see what you think of them. Another thing to consider is...are there any nightschool type training courses in your area for motorcycle mechanics?
  6. Airhead replied to syllabus's topic in Naked
    If you want to post an intro 'The Bar' will be a good place to do it
  7. I have a Rover 25 car that used to belong to my eldest daughter, she upgraded in August 2008 and this car remained un-used on my drive for over 18 months. My youngest girl passed her test in due course and to give her driving experience I had to swap cars and start to use this Rover car (which has cost me a small fortune) I was worried about trying to start it due to the ancient fuel, not least because it had been hanging around in there all through last winter which was the coldest on record Any way one new battery later and a turn of the key......Vroom The exhaust needs replacing
  8. I agree but why quote the number...he cannot delete it from your quote
  9. Airhead replied to DeTour's topic in Classics
    Sorry Cynic I may be barking up the wrong tree, this may be that other one you mentioned, I think it was decided in the other thread that it was called an avalanche diode (much the same as a zener) and would attempt to control the charging voltage.
  10. Airhead replied to DeTour's topic in Classics
    isnt the diode item 15 in the diagram? Like Cynic said earlier it's a half wave rectifier to charge the battery. The battery would supply lights (except headlamp), instrument lights, brake lights, turn signals, horn to name but a few.
  11. Airhead replied to MasonHart's topic in Classics
    Another zoomable diagram Bikebandit
  12. Hi not familiar with the bike and without a picture will have to guess about what you are referring to. Theses'needles' that apparently have threads on them! Could one be a throttle stop (idle adjust) screw, theses usually have a large and sometimes knurled head. this is used to set the correct idle speed for example 1000 rpm. Could the other be the mixture screw? these are usually made from brass. These have a setting from gently closed, for example 1 1/2 turns out.
  13. Tank has been done Vez, well at least the venting cap.
  14. Have you checked the fuel flow into a container...fuel tap filter?
  15. Hey, that nice of you to say so Gordo, this site is much better than twitface because of the common interest and good natured humour, we have had a good summer this year up to now, hence the hose pipe ban in my area, that will no doubt last until winter +1 on the ride safe. ...Paul
  16. Welcome Bas, i'm sure your friends dad will see that it is a good buy for you
  17. sounds like its 'running on one', to find out which side is easy, the exhaust is hot on just one side DONT BURN YOURSELF CHECKING !
  18. Hello and welcome James, not sure if this is any use or what yours looks like but theres lots on ebay Here ...Paul
  19. Airhead replied to mervin's topic in The Bar
    She's the spit of her mother
  20. Airhead replied to richard dt's topic in General
    Nice one Richard, old DT's are a favourite on here. Would like to see it, learn how to post pictures...see FAQ's I suggest the obvious...ebay Welcome to the YOC forum ...Paul
  21. It could be a coil in the magneto or the pulser coil going open circuit when the engine gets hot. There will be tests to measure the resistance of these things so if you learn how to do that and then test when it cuts out you may find the faulty item.
  22. Airhead replied to Vez's topic in General
    The bmf and mce in partnership: You may have read about the bmf and mce in this month's Motorcycle Rider. The bmf and mce have entered into a partnership agreement with the objective of both parties working together to benefit each other equally, mce will be promoting the bmf and actively working with us to encourage membership and add additional sparkle to the shows as well as offeringbmf members and affiliate members the best insurance deals around. Thebmfwill benefit financially from this association, getting a quote from mce through our website link will benefit you and the bmf, and if you take out insurance with mce, we benefit some more. Click here to discover just how much you can save. Check it out and see why mce insurance makes sense for you and sense for the bmf too! The weather is set fine for The bmf Kelso bikefest - July 10 and 11th, So why not make a day of it and ride out to see us. The third bmf show of the season moves to the North of the country. Set in a stunning location (so good weather is definitely hoped for!) this show is shaping up to be a real cracker in 2010. With over 50 trade stands booked and several hundred campers already pre-booked to enjoy the weekend, this show shouldn’t be missed. Kelso has always been a fantastic show from which to start a mini break and spend a few days touring the open roads of Scotland. With arena entertainment during the day and live bands (for those camping) in the evenings including Needless, The Band from County Hell and headlining the brilliant AB/CD - you can be assured of a great weekend. The bmf Tailend Show 18 and 19 September With a new location for 2010, the bmf’s end of season show is going to be given a major facelift. A new location in Lincoln at a stunning show ground means that traders, campers and visitors have something NEW. So get booking now by clicking here and be part of the action! Trade stands are already booking in fast and the entertainment is going to be first class with Steve Colley’s stunt show, the amazing Bolddog Lings (defying gravity most of the time!) and other arena shows. A giant screen will be showing a film on Friday & Saturday evenings and with Moto GP practice on Saturday and the race live on Sunday, it’s a chance to see great racing with a great bunch of people. For those camping, the evening live entertainment includes: Bad Penny, the ever popular League of Mentalmen, the Femones, Trash Monkey (after a very successful bmf show appearance) and James Toseland’s Crash – it looks (and will sound) great. There will be special show offers and for those who join thebmf during the w/e there will be a free prize draw to win a Valentino Rossi signed replica helmet – so even more incentive to join the organisation that works for and protects motorcyclists' rights. The National Rally We would like to congratulate all those bmf members who competed in the National Rally, write in and let us know how you did so we can feature your efforts in the bmf's Motorcycle Rider. To unsubscribe please e-mail a [email protected] and type in unsubscribe in the title bar and click send. 2010 show dates: bmf May show: 15/16 May 2010 Gems: Garden of England Show 12/13 June 2010 Kelso BikeFest: 10/11 July 2010 Tail End: 18/19 September 2010 www.bmf.co.uk
  23. Airhead replied to Vez's topic in General
    http://www.bmf.co.uk/pages/contact.php
  24. Welcome BartekGo, so you got that bike for a snip eh snip snip....Oops
  25. Airhead replied to Vez's topic in General
    Sometimes being a member of a motorcycle club can reduce premiums, I dont know if the YOC will count but others do, I am a member of one of the biggest, the BMF
