hi members
Welcome in mike, always good to see a proper intro, love your 'tools of choice', weve got fans of all your bikes on here, myself I fancy the TDR
How to Put Stripes on with new paint job
Hmmm whats duck tape
BW200 dies for no reason?
what about vacuum? runs for 5 mins as vacuum gradually builds then stops? fuel starvation? open the gas tank filler try again...blocked vent? Draining the bowl will release vacuum but fuel will still be there, vacuum with oppose the vacuum developed in the manifold. Also check the carb vent is clear.
Hello
welcome to the YOC forum 4x4van, SC so you dont have much problem with rust
help. bike wont turn over
Whats seafoam? I would use diesel oil pour some into each cylinder and leave overnight.
New project on it's way
http://cgi.ebay.co.uk/nos-suzuki-ts250-oil-pump-assembly-/370378231374?pt=UK_Motorcycle_Parts&hash=item563c434e4e http://cgi.ebay.co.uk/nos-suzuki-ts250-oil-pump-assembly-/370378231374?pt=UK_Motorcycle_Parts&hash=item563c434e4e http://shop.ebay.co.uk/bloke0/m.html?_nkw=%28ts250*%2Cts+250%29&_sacat=0&_odkw=ts*&_osacat=0&_trksid=p3911.c0.m270.l1313
Post some sizes and drewpy will fab a new one from his lava lamp, or a mop end
Looks great mate, off to a good start now. Whats up with the zorst then?
Dt 175, 125, fuel tank sizes
Your bike whte tank, blue stripe...That has all the shape and style of a DT175/125MX model ask our Cynic about cobbing things in skips
wanted a 1973 dt 127 or 175
Yes an intro would be good Lewis > Oh and wanted ads should be in the wanteds forum. Welcome all the same, 73 DT's =
mechanical problem XV535 , help needed please
I dunno mate, you'll get it sorted. By the way i'm no expert on that bike, just trying to help
Just say hi !
Welcome Oleg, we dont get many Russians on here. ...Paul
hi szr660
Greetings szr, good luck with the sale and the search for something else.
I got a new one year contract.
Great news mate.
if you dont have a spark, try putting the front plug in the back and check again, at least you know the front one is a good one. That should eliminate a duff plug fault. place jump starter leads round the threads and connect them to a good earth when checking, or wrap some bare wire around them also securely grounded.
sounds like your back cylinder isnt firing at all, under no circumstances should you be riding it like that, I cant believe you are riding it 13 miles. You should remove the spark plug from the back cyl and check for sparks, it seems there is some fuel getting there, it will go through to the exhaust, thats what you can smell. Who knows how much fuel you have in the exhaust after that amount of miles? just make sure nobody stands behind it for a while
Progress / Plans / Paint stripper from sainsburys?
Dont use paint stripper on your plastics Liam!! Just rub them down and use flexible primer on them before the top coat.
- 79? mx175
noob
No...its funny though, at least you posted in the noobs, it's the ones that dont that 'pees people off'
noob
Just coz you found fluid in yer exhaust Greetings
fluid in my exhaust
leaking head gasket? did you fit a nrw one and torque it?
- TZR50 cheap tuning
Tried to awake the Bandit from hibernation
Ha take that you awkward b4st4rd, ....just sorned it
Yes it could have a blockage to the fuel feed in the rear cylinder, either at the carb or the pump (depending on the plumbing arrangement)
- Hi
