Bout to pull all my hair out
great news mate. Cant help with the fuse question, why not buy a used manual from ebay, I couldnt own a bike without having a manual for it.
New guy from Scotland :D
Greetings kenny
Tank Stickers
Nothing more powerful than a hairdryer mind...dont use a hot air gun Once you have a corner peeled up...play the heat near to the corner while gently pulling up the sticker.
Take a chill pill and check if its sparking, take it from there
1999 DT 125 R or 2004 DT 125 RE?
I would go for the RE as it does look better. However I bought a 2003 DTR last year and it was most definitely money well spent, superb little bikes. Good choice and guaranteed to increase in value IMO Simon
Engine Overhaul - DT 125 LC mk1
Another £55 on parts Might as well forget it right now
New to YOC
Ohh my bent forks too? Theres one on ebay for spares...in yorkshire
- Shocked
New to YOC
Greetings Alex , parts are quite rare and expensive now, look out for a good exhaust if yours is rough....a picture?
Luggage solution
Drewpy has one too, just the job for rally's and the like
Dt175 performance question.
She's coming along nicely now, put the standard exhaust on last weekend for the first time since I removed the pipe in the header. My SM tailpipe?...well that needed re packing so instead of my usual re-pack using baffle wool (fiberglass) and packing it real tight like I have done for the last few generations I decided to try some filter sheet from work, looks a bit like the baffle sheet that is sold for purpose. Well I was shocked it felt a hell of a lot more torquey on the ride home but noisy, yep too noisy really so today I fitted a bog standard steel one, what a lovely sound, it's been so long I forgot what they sounded like...much more neighbour friendly and performing way better than the Gianelli / SM combo that was on last week, more than likely due to the silencer packing method I had used.
dt175e regulator location
Yes it's at the bottom of the battery compartment, near the drive chain
- Rectofier question
Take the way you got no reading...was the red lead on the male connector?- Front brake issues
I dont think you are supposed to split the caliper in that way, I think it should have been left sealed and you have damaged the seal.- Rectofier question
Switch it to 2k Ohms and plug the leads black in com and red in the ohms socket. Now test the two connectors on the rectifier, you will see a reading one way only...verify this- Rectofier question
I reckon the red goes to the male connector of the rectifier. Have you got a multimeter?- Rectofier question
Are your wires red and white? isnt there male and female connectors on it that would prohibit getting it wrong? your wires, they have male and female connectors ...yes?- Rectofier question
is there a diagram on it, like a triangle with a line across one of the points?- new
- New to this forum
Greetings Ma;colm- Hello from Nebraska
Greetings rocknroll- Email Notifications
Hi Jay, yeah 'watch topic button will give you email notifications. On the otherhand you can see which threads you have had an input in by looking at the icon of the thread, if theres a little white mark in the corner you have posted there, and if the icon is dark there are new replies to be read...much better than cluttering up your emails. Save notifications for something important to you. Another way is to click onto the little green icon next to your user name, a pop up will appear and one of the options is to see your topics (bottom left) ...Paul- Greetings and salutations.
Greetings Dave
