Airhead
  1. Greetings funfly I see you are a glider pilot ?
  2. The DTR will have to go A new bike in the stable http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260818099825&si=sXg1i7yj2ESDUUmwhxDFinFzn%2Fo%3D&print=all&category=9809
  3. Slow fuel supply through your tap...blocked screen either in the tap bowl or within the tank?
  4. Can I suggest you size your pictures to 600 - 900 pixels width if you have the means ..can be done on photobucket but theirs is a bit slow...myself I use paint.net, not essential but they can become tedious waiting to load up in your posts when taken with todays crop of huge megapixel cameras
  5. Pictures are easy when you get the hang of it. See the 'Pinned' topic in New members FAQ's
  6. Nice interesting intro there Scott Hope you make good progress with the parts, a member here had a disc cover in red for a DTR...dunno if its the same? ...Paul
  7. Airhead replied to clivew1965's topic in Yamaha Workshop
    OK Clive you should have a good look at the components or the carb then, make sure they match the spec I listed...everything...including the slide cutaway
  8. do you do CBT on your own bike then, might be tricky with a wide open PV (no bottom end power) . I know were making assumptions here at the moment!
  9. Airhead replied to clivew1965's topic in Yamaha Workshop
    Sorry to hear that Clive
  10. Airhead replied to clivew1965's topic in Yamaha Workshop
    Yours should be 2H500 Clive, if it has a 3U500 fitted that's your problem. You are seriously risking major damage with large throttle openings and only a 90 jet fitted! I would prefer to buy a used carb Mikuni rather than a copy RT?? will be much cheaper too £30 - £40 I would say This is what you need These are the spec's your carb should have Mikuni VM24SS, Number 2H500 Standard Set up with factory porting, standard exhaust and air filter Throttle Slide cutaway, 2.0 Needle, 4j13 Clip position 3 from top Needle Jet, 249 0-2 Main Jet, 130 Pilot Jet, 25 Reed side diameter, 35mm Filter side diameter, 43mm Length, 85mm Float Height, 21mm
  11. Greetings Dave
  12. Haha
  13. Airhead replied to clivew1965's topic in Yamaha Workshop
    Hi Clive, makes me wonder if you have a carb from a later bike marked 3U500 fitted to an early bike with access to the air filter on the right of the bike ??? That would do it! People advetise carbs on ebay ***DT175MX CARB*** what they often fail to say, probably because they dont know...is the id number on the carb. The two carbs are jetted differently and more importantly have different throttle slides. This was because of a revised air filter box on the later bikes, notably the ones with a square sect swing arm.
  14. Greetings Dean yeah looks nice but like NEV says...it sounds like it hasnt got a working PV. Can you hear a noise like zzzt...zzzt...zzzt when you switch the key on again after running the engine? I suspect not
  15. Greetings Pat Maybe it's best posted in the 'Workshop' ?
  16. Greetings barmyphil dont know about huge V twins sorry but nice intro sir ...Paul
  17. Good for you James
  18. Not saying its right merv but this could have been adjusted out...no?...using the pressure plate adjuster? same thing goes for yours James, if the new plates are not as thick then it will all 'bottom out' on the previous adjustment setting. Theres more than just the cable adjustment on a clutch...least thats my experience of em
  19. lots of people bleed brakes by the wrong method...are you one of those
  20. is it bike oil James...not general car oil?
  21. Greetings James. is there some slack in the cable? did you use bike specific oil? how about an intro in new members forum?
  22. Thats a bit of a coincidence Steve eh?...sure it's not just air? you wouldn feel any pressure
  23. blackhat had it
  24. Morning Gordo, I reckon a new coil would work wonders too, also perhaps a new HT cap the ones with a little rubber seal at both ends (NGK)
  25. is the sring retainer at the top of the spring still attached securely to the valve? you say the top of the spring moves up but you dont say the valve is moving! The usual arrangement is a couple of collets holding that top spring retainer, they sit in a groove around the valve. If they have come out you wont be using the bike any time soon I dont think
