Piston and Rings Replacement Help!!!!!
yes its + 0.75mm
Some help required
i'm ok...not watched it
hi from west midlands uk
Greetings wagy
hello guys
Greetings Gary last off the mark but still, its cheap to run eh?
newbie
lucky lew greetings
Hello
start a topic outside of here yamste in the most appropriate one Greetings
new member
Greetings lexie
Identification
What are the numbers Geoff?
Hello agian
Greetings Geoff aaah a DT
hello
Greetings John
Squires ride out - 3rd September 2011
Passing through Wheldrake
crankshaft oil seals
but what of the original seal...spring both sides ?
Engine bearings - What is your opinion please?
Bang on guys go for a quality name koyo fag skf etc, take advice from the retailer they know their job. you will also get oil seals too. The name I use would be brammer http://www.brammer.cz/uk_brammer_products.aspx
DT 250 Questions
This is my DT175 carb, your carb is similar maybe
The gang
DT 175 MX main jets
so you posted incorrect info in you original post thats why i gave you info for a 1981 bike! ok then for the earlier version Mikuni VM24SS, Number 2H500 Standard Set up with factory porting, standard exhaust and air filter Throttle Slide cutaway, 2.0 Needle, 4j13 Clip position 3 from top Needle Jet, 249 0-2 Main Jet, 130 Pilot Jet, 25 Reed side diameter, 35mm Filter side diameter, 43mm Length, 85mm Float Height, 21mm
DT 175 MX main jets
two points 1 if you do look to but a 2T res make sure you buy one for the later model with square swing arm, that one would mount on the right of the bike with air filter on the left 2 so the later DT175MX engine would have a carb with an id number 3U500 these are the original specs for that carb Mikuni VM24SS, Number 3U500 Standard Set up with factory porting, standard exhaust and air filter Throttle Slide cutaway 1.5 Needle, 4j6 Clip position 3 from top Needle Jet, 267 0-8 Main Jet, 160 Pilot Jet, 20 Reed side diameter, 35mm Filter side diameter, 43mm Length, 85mm Float Height, 21mm
Dutch XS400 2A2 Caferacer
Great she's a beauty well done, love the shiney pipes
DT175A Can't find 1st gear
sean is there a pointer on the actuator arm and a corresponding raised mark on the top of the crank case ?
DT 175 MX main jets
Mike jetting size depends on which model,I would go up 5 points on the main jet (whatever is in now) and premix 35/1 would be enough although myself I prefer pumped oil
Greetings from Vietnam!!
Greetings Scoops
kick return
I cant picture what you are saying about the melting but perhaps the kicker arm needs moving one spline anti-clockwise on the shaft?
86 XT 400 Gear Shifter Shaft
Not a bike we had here Ricky but I would think that you have been told right up to a point, they usually do pull out from the right side of the bike...this will require removal of the clutch cover and possible disassembly and removal of the clutch. You would obviously need a clutch basket holding tool in order to remove the centre nut. it may look similar to this but dunno for sure %201855V-300E1/SHIFT%20SHAFT/"]http://62.5.189.98/yamahaeur/user/moto/Motorcycle%201986-1992/XT350%2088/55V0%20(GRC)%201988%20[130]%201855V-300E1/SHIFT%20SHAFT/
Hey guys
Greetings Ricky
Help with DT100 - 31 years standing.
1 1/2 turns out is the norm.
