Airhead
  1. interesting topic tiltle richard...'trouble at mill?'
  2. have you got a haynes book steve? you need to test the magneto coils and the ignition coil, the figures will be in haynes book
  3. horn, tail light, turn sigs, pilot light and instrument lights need the battery Richard, headlight is AC straight from the flywheel generator, member NEO did a comprehensive topic on 12v conversion for these
  4. welcome in richard nice to see a decent intro yeah that are great little bikes, we call them DT175MX here
  5. Airhead replied to blackhat250's topic in Random
    Love it john, i've never seen one before, are they rare? that radiator is HUGE!
  6. how is it obvious? you will have to take the head off to examine the piston crown to see if it's been rebored, scrape off the carbon and look for a stamped number, you would need to order piston and or rings at this same size assuming the bore isnt worn out. I have used quality head gaskets twice (the black ones) with a very fine bead of silicone manifold gasket just around the circumference of the bore on each side and had no issues, dont plaster it on all over and thick or you may find it difficult to remove the head next time. Oh and dont forget to drain the coolant first, yes i have heard of people filling their crankcase with the stuff!!!
  7. Cheers mate???? listen pongo or whoever you are it's 'Airhead' The engines from early/later bikes can easily be identified by their different oil pump covers. Engine# is stamped on the elevated part of the left rear section of the engine
  8. The blade is something else...one to cherish
  9. fazer would be a better option for 40 miles regular M_way
  10. youre welcome http://www.google.co.uk/search?q=xs1100sg&hl=en&qscrl=1&nord=1&rlz=1T4GGLL_enGB401GB402&biw=1024&bih=540&prmd=imvnsfd&source=lnms&tbm=isch&ei=ps5CT6SoGeSh0QX50NSODw&sa=X&oi=mode_link&ct=mode&cd=2&sqi=2&ved=0CAwQ_AUoAQ
  11. 3J6 3J6 0000101 0060000 XS1100SG 1980 Vins 0000101 to 0060000
  12. whats your vin?
  13. come back 'Gas up-Lets go'
  14. lol the clown car horn Greetings blackmun post up a piccie
  15. just goes to show what having very little power can do for your pocket eh
  16. does the horn work ? and for a first post not even a hello, hi or better still something in the NEW MEMBERS forum
  17. Greetings Matt yeah we love the DT's here and and you'll no doubt gets the advice and help you are seeking also nearer to home is http://www.yamahait.com.au/forum/index.php/board,24.0.html
  18. whats wrong with it dan, it may be blocked and need the same cleaning regime as the carbs...it's very likely
  19. err why ask for something and then not reply? anyway i have found one for you if it's not too much bother!
  20. Greetings ronnie what bike are you going to get next?
  21. yeah whatever you do dont break it
  22. i see the specs are in the haynes book
  23. aye mate it looked a great day for biking but the bandit's still sornrd till march...really missing it now!
  24. Airhead replied to bindie's topic in Random
    now that IS an old one
