Airhead
  1. DEP is make of a popular after market exhaust often fitted to DT125R's
  2. just remove what you can and blank off the pipe, it's to do with emissions. DT125RE's have this thing also and they have to do this when DEP exhausts are fitted...I have sent you a PM
  3. Airhead replied to Sacha's topic in The Bar
    Change the battery, i'd put money on it that it's no good from your description of it. Buying or finding the meter would be a good move also, then when the new battery is fitted you can check it's charging by measuring the voltage increase with engine running.
  4. Airhead replied to kearnsy123's topic in The Bar
    what about the cleaning !!!???
  5. unscrew the screw by about 7mm but leave it in, then tap the screw back into the bar end, keep it pressed in to the bar end and try pulling the thing off like that try posting smaller pics it takes an age to load and edit your mega mega pixels!
  6. yeah its annoying when posters dont follow up what they start!...not been back since Sept 2011
  7. nope they have written off May already :( :(
  8. Aye most of us just tell her ask her nicely if we can have another bike...like your style 'icedragon' Greetings and
  9. Welcome back Dan
  10. check tyre pressures steering head bearing play wheel bearing play suspension play
  11. Greetings JaK and
  12. Greetings David welcome to the forums
  13. Its wet and bloody freezing here
  14. Greetings OS nice bike the YBR, how does it perform compared to the R125?
  15. Greetings DF , your bike looks mint
  16. wow...you've got a door to Japan
  17. I wonder if forum member majormods will know? he's a dealer in US so might be of use?
  18. when you say 'The Block' are you quoting the number from the engine case, not something on the cylinder barrel?
  19. or two..a 106? thing is it WILL apparently run ok with the 102 but it will no doubt overheat and may burn your exhaust valve
  20. I think they are being a bit 'generic' saying VM24 - 44, the carbs are made specially for yamaha model specific, i'd buy the next one bigger...than? did you try raising the needle yet?
  21. Airhead replied to NEV's topic in Yamaha Workshop
    Test with a multimeter NEV, are any of the spades connected to the iron core (no resistance)? if so you can either attach the black wire to this one or just not bother and rely on the mounting bolt...or both
  22. Cheers mate, have a good one yerself too
  23. FFS!!! Check the magneto rotor hasnt come adrift
  24. Can i be frank...It's Paul Pete
  25. is your chain loose, worn out, sprockets worn (front and back), teeth missing??? ...all generally neglacted and sad If the answer to any of this is YES you are risking personal injury or worse god forbid because if that chain breaks you can suffer serious injury! and engine case damage
