Known symptoms of Faulty XV125 TCI/CDI Unit - please contribute
has it got a sidestand switch kelum?
2001 DT125r won't go over 55mph
did you check your power valve is set up properly to fully open?
De Restricting my DT125R
thats all you have to do ben
DT125RE WONT START
Have you ever had the magneto rotor off? If so did you torque the nut up to the recommended specification? A rotor nut not torqued up properly will shear the woodruff key and render the bike sparkless!
- CDI Units
Which bike should I fix?
yeah fix em both if you need any help...just ask we have a few USA DT owners on here who i'm sure would be glad to help out too
oil coming out of air filter, Help Please!!
my guess and that's all it is worn piston rings causing blowby and pressurising the engine block? But of course you should check the oil level is correct
Took my wife to a disco
Thats how the fight started
see my pinned topic in the dualsport section
- HAPPY FATHER'S DAY! I
Postie bike kickstart wont move.
sounds like it's seized to me too. What exactly is a postie bike then?
My application to be part of your motorcycle website.
Greetings Dave and
DTR 125 Help please
hissing is normal paul, try another spark plug
DTR 125 Help please
I found it nigh impossible to torque every nut on mine due to various gubbins in the way, so i torqued the ones i could and did the others by hand
1993 Yamaha SRX400???Need comfirmation
1993 XJ400L me thinks
need help with my tzr 50
is it possible to change this speedo then? or is the bike an import and no such change feature exists?
TZR 250 no power under load.
is there slots in the maneto flywheel...any chance you could spray through the slots? spray WD40 at the seal when the engine is running...listen for a change in engine speed / tone to test the seal
isnt the SRX a single cylinder bike? that looks a bit like a diversion or summat!
DT175 MX newbie
you will need to open a photobucket account for yourself, upload your pics to your photobucket account, then you will be able to post them here...it is well worth your while learning how to do this because questions can sometimes be so much clearer when backed up by a photo see the FAQ's sub forum in 'New Members' for more explanation
which side smokes more...the right (clutch) side ?
SR500 wheels and spokes
i think you will find that some of the spokes get in the way when tring to remove others but im not talking from experience here. I you do strip the wheels down entirely dont forget to note down the offset before you start
DT175 MX newbie
Greetings Phil and it will be interesting to see you sort the old DTMX out...well to me it will post up a
The Regular Birthday slot
Happy Birthday blackhat and yamahead
Yamaha V50P 1976 - tidy up
kayos did you get her going?
XVS 950 will if fit through my gate ?
Neil i'll have to ask the obvious question here...If it's too wide leave it at the dealers untill the gate is widened?
