starting??
a duff rec/rec unit can indeed be the "short in the electrics" you refer too Paul. a simple check of the diodes perhaps?
starting??
battery dies with no key in the ignition? possibly a duff reg/rec unit?
[HELP] Yamaha HT1-90
any motorcycle specific engine oil is ok for the gearbox godslam, dont put car oil in it may cause clutch slip! I assume there is also an oil tank for the two stroke oil... This will be very useful though http://www.repairmanual.com/online/official-1970-yamaha-ht1-factory-service-manual-u-yam-s-ht1/
'allo.
Greetings godslam, hey i've never heard of that bike...any chance of a picture?
DT125RE WONT START
did you not see this keiran???
Known symptoms of Faulty XV125 TCI/CDI Unit - please contribute
as far as the timing goes i can 'slip' because of either 1 or 2 things 1; the stator screws have come loose and the backplate has moved or 2: The rotor woodruff key has sheared because the rotor wasnt torqued up to the specified torque setting
Newb!
Fantastic!!! looks a minter
What restrictions do old DT175's have?
the only true restriction i have seen with the mx was a tube in the exhaust header...however they dont all have it and theres nothing to say yours has and from how you described its performance it seems yours is a pretty hot performar eh? you never did answer the question about your MX though ?
DT125R 02 MODEL...HELP.....
as far as i know they are the same dom, anyhow you'll get one from ebay in due course
- CS5 armature removal
Carb balancing? HELP!
just a thought I did mine on my bandit last weekend, speed is of the essence because essentially the bike is air cooled and with an idle speed set to 1750 it gets hot quickly
- 2 Stroke gathering & YOC camping weekend 2012
- '78 Suzuki TS250C project
Hello to all. This is Daddioduncan.
Greetings and Duncan
Newb!
Greetings Beth, what an awsome beast of a bike heres a big cheesy kiss for you
Thats really looking good now dirtydt
1984 DT175 MX - 12 volt regulator to complete my 6v to 12v conversion?
By all means you can call me Paul...and you are? Get yourself a new NGK 5k ohms cap I take it you subtracted the figure you get from your meter leads only? if so it's out of 10% spec as it says...its the HT coil primary and the tutorial says you should be checking at the disconnected plugs and sockets to the CDI...It's orange there, you already said that yours was high at 1.8 ohms...was this directly at the HT coil and not the loom connector to the CDI? Good Its seems that someone somewhere along the line has replaced the pulser coil for a mk1 jobbie...dohh! I expect this will inadvertantly advance the ignition somewhat! Good Speed reading again lol...at the disconnected (loom side) CDI terminals
DTR 125 Help please
but you recently fitted a new key and said you were torqueing it up, if you did it right this cannot happen!!!! This time do it right eh
Dt125R - 1997 - Coolant problem
the only time mine leaked from the overflow through the frame was when the cheapo head gasket was passing, i fitted a new 'proper' one and all was well thereafter
New head gasket Toby, nit a cheap metal one, gett a proper black one from yamaha or athena
- Hi To All
New to bikes
Greetings Ted how are you finding the cat?
Hiya from F26
Nice intro fletch
New guy
Good choice fella
what i am saying is...yes the later mk2 had only 1 coil and no red, however the coil ohms value is different to the larger of the 2 coils in the mk1. You said you checked in the haynes manual and yours was in spec...but which model were they talking of? perhaps your stator coil is indeed out of spec?...all will become clearer when you study what i posted. do the checks that are applicable to yours it does seem it may be an electrical issue now that the choke made no difference
