Airhead
  1. dont forget that there may be nothing really wrong with the regulator. It may simply be a bad connection, broken wire, insecure ground etc
  2. yep I've been missing Pat too, hopes he's OK and is only sick of us lot
  3. youre not copying the 'IMG Code' ....Thats the one to copy and paste in the forum, nearly there though
  4. Thats not gonna happen Rob
  5. Airhead replied to drewpy's topic in Projects
    Lets place bets on a: regular stoppies b: bent forks c: regular wheel lockups looks good though, is it going to stockport then?
  6. see FAQ's subforum to new members forum for pics Rob
  7. chances are Rob that it's only your battery thats sh4gged, get a new one and then do the tests on the charging voltages
  8. The key would have been the same as the ignition key unless someone changed either of them previously
  9. I have seen the USB turntable in aldi at some time, they'll probably be back http://www.aldi.co.uk/uk/html/offers/special_buys3_19125.htm
  10. For those of you with siver machines http://www.youtube.com/watch?v=O7up1MzwxhI
  11. Thats a pity merv ahh well maybe next year eh
  12. Very good interesting post there Mark
  13. Greetings mate and even if you've been around for a while eh Hey you've got some great bikes there
  14. Airhead replied to Martineer's topic in Projects
    It's a 1973 YB100 https://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GGLL_enGB401GB402&q=1973+YB100
  15. Ha greetings Jamie bet I'm older than your pants! ,
  16. It is really unlikely that you will need either a float or a needle, usually the float needle valve may have just jammed sometimes a gentle tap on the carb with the wooden stock of a hammer will free it, but as we have said before the vacuum tap should be stopping the leak anyhow Starter motor?
  17. with hardly any mechanical ability I would think It's best to have the job done for you. It's sounds unusual that both should be leaking and I take it the stancheons are not pitted anywhere in the working area? is there a manual for this bike? it may be in the manual how to do it
  18. they all smoke and smoke a lot more until the engine is warmed up The pump will deliver a metered quantity, this isnt really adjustable...is it an issue there then? :greetings and
  19. You'll most likely have to go to a yamaha dealer dave, If thats not easy for you try phoning one Fowlers of Bristol if you cant find help locally, you'll need your model code I guess, is there a sticker somewhere on the frame...perhaps beneath the seat?...sorry i'm not familiar with the model but others on here have them
  20. Get it in your diaries everyone Friday 13th - Sunday 15th September
  21. you could try sucking on the vacuum line a few times to test the action of the flow / no flow
  22. Yep youre right Dave, if the vacuum tap is working this cannot happen! so where is the leak coming from then?
  23. Airhead replied to Martineer's topic in Projects
    is it a YL2? https://www.google.c...02&q=yamaha yl2 For pictures see FAQ's in the 'New Members' section
  24. Looking forward to this one NEV, Yeah liking the seat...very nice
