		1992 DT175 Idle cut out
		we never got that updated model here in Europe, by 1984 we had moved on to LC's so on the model we did get...there is no need for said T handle, we just unscrew the allen screw out of the bottom of each fork leg
 - Village shop
		Village shop
		good find mike, bet you'll be back there sometime
		dt black and green wire
		Its only on the RE version mate
		MOT
		not sure but i would guess no, I know for a fact though that a pair wouldnt be needed
		*Yamaha TZR 50 - Speedo Problems*
		see here nicsy and feel free to post a little intro in 'new members'...Thanks
		hi all, new member from lincolnshire saying hello
		Greetings marshie lets have a look then
		Nicknames
		Havent you heard ian...It's 70 now fella
		SUZUKI 400 Bandit!!!!! WTF?
		wow thats a great find slice, cant wait to see the pics
		Gilera 4V project
		looking great drewpy...keep the momentum up love the handlebar how was the kicker you picked up from Stafford then?
		Hi everyone, new guy, old bike (Thunderace)
		Greetings Rich
		Engine is heating up.
		There is a polished ring around the circumference of the flywheel rotor! is it rubbing on something...rubbing = friction = heat ? how did this rubbing occur?
		Yamaha SR125 CDI Wiring
		yeah check the ohms value of the source coil and pulser coil and compare them to spec usually + - 10% specs in the workshop manual and sometimes in the parts book under 'Service Data' also the ignition coil (HT coil) can be checked against spec in the same way Yes the source coil is power and the pulse coil is trigger for the ignition is the HT cap to HT lead connection good? I'd try a new cap and cut 10mm from the end of the lead and re-make that connection...caps are usually 5k ohm but again that will be in the manual
		n i'm not familiar with the bike ade, nor do I have a wiring diagram to refer to However, the bike is a single cylinder so it will only have one pulser coil...the other coil being the 'source coil'. is there a brown wire to the CDI? brown is often the switched live on these older bikes but not sure about yours the collection of wires to the stand, clutch and neutral will take care of the safety interlocks, the ignition will be cut if put in gear with the stand down...maybe not if the clutch is pulled but I dunno about that black wires are chassis or -ve and perhaps each of the engine coils have a black connection?
		Cagiva4ever , 125cc 2T collector
		wow thats a really comprehensive intro 'm' Greetings and to the YOC..cant beat the 2T's they're such fun
		Happy Birfdy Merv
		Happy birthday merv and a belated happy birthday preload
		whats is it like with choke on...any better?
		Hello new member here,thought I had better say "hi" first
		greetings Sue , whatever it is ask away in the appropriate forum
		Ade joined from Nottingham
		Greetings ade
 - Stator wiring
		post pictures emil, it is hard to make any judgement without seeing what you see yourself
		30 today!
		happy 30th birthday mucker, my bike is older than you, maybe my underpants too !
		clutch arm spring popped off!!
		yeah barb maybe your spring has been strained it isnt normal in my experience to have to turn them more than about 1/2 turn as you say. The clutch plate springs should do most of it though so i'm wondering if there is something stiff or the cable not routed right as well?
		cant see you needing to wrap it back anything like the amount you are saying, secure the fixed end into the case? then just hook the moving end over the arm...that's it
 - Stator wiring
