Airhead
  1. Airhead replied to drewpy's topic in Projects
    isnt there lines on the rotor and a mark on the casing?
  2. Airhead replied to drewpy's topic in Projects
    That head has an awful lot of finning looking great mate
  3. Not on these carbs John, dont have to risk it
  4. I can understand your concern ...just do it with the jet still in there, why not? you should still see the fluid coming through
  5. use a straw on your carb cleaner aerosol to spray back through the two holes in the diagram and witness the cleaner coming through the pilot jet
  6. if you couldnt get it out but can see light through it the jet must be clear but how do you know the little passageway is clear through to the venturi? did you spray carb cleaner down and witness the passageway is clear?...see the diagram I posted in your other thread
  7. I answered your other post! before I saw this one not good is it
  8. I remember ya Dave, welcome back fella shades of the past
  9. you double posted this...tut tut!
  10. yes quite likely Slacken off the cable adjuster Take a hold of the push lever at the engine and push it forward until it resists movement At this point the pointer on the end of the push lever and the pip on the casing should align, use the adjuster in the centre of the pressure plate to achieve this alignment Now adjust the cable adjuster for approx 10mm of free play at the end of the lever If the alignment of the pointer and pip is not achievable, then check the wear of the plates by measuring them with a vernier caliper and referencing the specified thickness and wear limits in the manual
  11. Feck me, this got me going!!! http://api.viglink.com/api/click?format=go&key=bbb516d91daee20498798694a42dd559&loc=http%3A%2F%2Fwww.the2strokeforum.proboards.com%2Fthread%2F8901%2Flandrover-runs-bikes-chased-bikers%3Fpage%3D1%23scrollTo%3D95630&v=1&libId=9e6730e2-ffed-45f7-81b8-b1d84a21be1d&out=https%3A%2F%2Fwww.facebook.com%2Fphoto.php%3Fv%3D153102431566769&title=Landrover%20runs%20over%20bikes%20then%20is%20chased%20down%20by%20bikers%20%7C%202strokeforum.&txt=www.facebook.com%2Fphoto.php%3Fv%3D153102431566769&jsonp=vglnk_jsonp_13805753275936
  12. just how do I embed it...cant seem to do this any longer...I used to just copy and paste the youtube browser but I doesnt work any more?
  13. Airhead replied to DirtyDT's topic in The Bar
    Nahh, not got one fatso
  14. petrol disolves araldite i'm sorry to have to inform ya of this
  15. Airhead replied to a post in a topic in New Members Welcome Area
    Greetings Tim
  16. Airhead replied to drewpy's topic in Projects
    Still dont see why you believe this to be the case??? normal engineering practice is to pull/push the shaft through the bearing,
  17. Airhead replied to drewpy's topic in Projects
    you need to be careful here mate, the bearing should be in the case and not on the crank before any attempt at assembly, the same thing sometimes happens to DT's whereby the bearing stays on the crank during disassembly but It's not supposed to be that way!
  18. yeah you should do a good job with sorting out the exhaust next as it may contribute to the problem
  19. 1st Day Back at School Attendance call on the first day back at school in Birmingham , UK . The teacher began calling out the names of the pupils: "Mustafa Al Eih Zeri?" "Here." "Achmed El Kabul?" "Here." "Fatima Al Hayek? " "Here." "Ali Abdul Olmi?" "Here." "Mohammed Bin Kadir?" "Here." "Ali Son al Len” Silence in the classroom. "Ali Son al Len" Continued silence as everyone looked around the room. She repeated, "Is this the name of any child here?" A girl stood and said, "I think that's me, Miss. It's pronounced Alison Allen"
  20. OK then, elec start only...It may benefit from a bump after squirting in a little fuel (10cc) or charge the battery fully and try the button
  21. Greetings Graham
  22. try squirting a bit of petrol down the plughole, see if she catches maybe try a bumpstart too...it should be easy enough on that bike? edit...I'm not familiar with the haves and have not's of every bike of course...is this one elec start only?
  23. Hi Graham, so how do you know you have the fuel ingredient...is the plug getting wet with fuel? Taking apart the fuel doesnt mean It's getting in the cylinder if theres something wrong with the supply,,,Filters...Fuel tap etc
  24. Better late than never Chris, the little YBR is a great choice 1st bike Greetings and
