Airhead
  1. Some nice bits there steve esecially thr rear sets whats the mesh is it a rad cover?
  2. what dirtydt means here is compression is aided by a film of oil in the bore and around the piston / rings. Repeated attempts to start can mean that the petrol washes this oil away and to some degree the 'seal' needed to aid compression is lost so compression is reduced. Try squirting a little engine oil down the spark plug hole to improve the seal and maximise compression. Attemp to start with choke and little or no throttle
  3. Nice little intro Kim, welcome in fella
  4. you'd have to remove the casing and also have the correct tools to remove the flywheel Andew, cant be too specific...i'm not familiar
  5. if there's any chance the chain stopped the engine turning suddenly (which it seems likely) then maybe you should check the flywhhel woodruf key hasnt sheared. If it has, this could be a reason for a poor spark
  6. you've been asked this before ...did the incident lock the engine...a very sudden stop?
  7. Airhead replied to jackm20010's topic in Video Section
    keep up the good work Jack, ya gotta start somewhere and if it's what interests yo go for it fella, the go pro is a good camera, just need some good subject matter next...give it time and dont be disheartened by some of the feedback you get
  8. thats just so very sad Tommy
  9. Cool, it's funny how these things just come up out of the blue eh...looks great well done
  10. BTW chains 'stretching' is a myth...they wear the drier they are, the quicker they wear...
  11. Also available in red http://www.gumtree.com/p/cars-vans-motorbikes/suzuki-dr650-enduro/1044691102
  12. I can only assume the £75 is because they are painted, it takes an awful long time to strip painted parts using paint stripper and aqua blasting, I've had quite a few barrels and heads done this way but this week I took two barrels to the aqua blasters and only paid £30 the pair, ....and they're aircooled so more work needed. I stripped the paint off myself this time and benefitted from a fast turn around. Get youself some 'synstrip' it's the only stripper that seems to work nowadays and soak the barrels for 1 1/2 hours in the stuff followed by a jet wash. in the past It's cost me £20 just for one cyl head because of the time it took!
  13. Airhead replied to drewpy's topic in Projects
    Jeez thats a bummer about the yoke Drew But air rifle practice , your scouts do cool stuff man but, ahem when I was in the scouts we went to shoot real rifles at the army range
  14. +2 with the neutral switch...neutral light? C'mon Andrew, chains break through neglect...I'm not preaching, I've done it too!
  15. Airhead replied to slice's topic in The Bar
    Rub it down, rattle can it with high zinc primer, top coat with something like black frame paint http://yambits.co.uk/black-frame-paint-p-32020.html
  16. yeah just do a search for TT600RE
  17. Airhead replied to drewpy's topic in Projects
    Sounds good mate
  18. if it werent for the lack of space i'd probably have a MZ250 now
  19. Nice one Stuart, good to see you back in the fold and heres to a summer like the last one for you to get some miles in
  20. Nice one Numan, you're gonna have to get another shed built
  21. have you got the bike home? Have you got a charger? BTW, putting the side stand down when the bike is 'in gear' WILL cut the engine, it's a safety feature so you cannot ride with the stand down and maybe come to grief on the first left hand bend you come to.
  22. One of the BMF shows would suit us well too, lots to see n do
  23. could be your battery, is it kaput...does it just need topping up with distilled water?? Could also be your voltage regulator = kaput
