Airhead
  1. Good choice John, the bike looks great
  2. Airhead replied to jimmy's topic in General
    for the right crimp tool for the japanese 3.5 bullets google 'uninsulated crimp tool'
  3. why do you think fitting a bigger jet will help Tom? after all It's only ever going to be a 12hp bike and fitting a bigger jet isnt going to change that...that's for sure
  4. Thays bloody lovely, now get it sold and buy a stroker
  5. take some tools on your trip Tommy
  6. so eagle wants to fly Greetings and
  7. Check 'A' is not blocked Check the gasket around 'B' is not broken / split
  8. when starting from cold..... switch on fuel pull out the choke knob kickstart with little or no throttle (choke wont work properly when throttle is opened) when it fires up, use gentle throttle control to keep it going choke off after about 1 minute
  9. welcome back mozzy, lovin the baby XT what a great buy
  10. Greetings Tony
  11. nice I suspect the DTX's days are numbered now
  12. There may be no filters in the tap, if it has an obvious bowl there shoud be, either way you need to sort this issue though. I do have to ask you this though..........when you reported a poor flow earlier when torned to ON..........you DID have lots of fuel in the tank eh....eh....eh??? Just looked in my manual, theres only the filters in the tank;)
  13. well if the filters are clean and you have a poor flow on main supply, then something's blocked in the tap, so either clean it again untill it's fixed or replace it
  14. I'm more concerned about the fuel delivery right now, just back out the mixture screw to 1 1/2 turns for now and sort out the fuel delivery, there are often 2 screens, one is inside of the tank and will need the tap to be unscrewed off to get at it, the other is often inside of the bowl of the tap isnt there a hexagon 10mm at the bottom of the bowl? *** IMPORTANT*** Always use a 6 point socket here unless the bowl comes off easily, dont force it or you'll risk rounding off the soft metal
  15. you might not need a new tap Hitch, maybe the filter screen in the bowl is dirty, or one of the tubes that go inside of the petrol tank (part of the tap) This problem will have contributed quite a lot to all of your troubles I'd say
  16. Airhead replied to lauragilmour's topic in Projects
    Great pics Laura and yeah it's nice to see you out and about with dad
  17. Great news kim, have fun
  18. How come after all that time you never mastered it?
  19. yes the oil light should be on in neutral, it's a bulb check feature. Check your bulb if yours doesnt work. First gear should always be an easy change, sometimes neutral is a little more difficult. I'd check the clutch adjustment for this
  20. maybe its very similar to the DT175 unit? have a look at this, check out the plugs / sockets and wire colours and the switches http://www.ebay.co.uk/itm/Yamaha-DT175-1978-81-LH-Handlebar-Switch-QS3H7-/321174749794?pt=UK_Motorcycle_Parts_13&hash=item4ac781c262#ht_3863wt_721
  21. well thats surprising
  22. dunno about the possibilities but be aware that if you raise it significantly it will lean over very heavily on the stand!
  23. send an enquiry to Fowlers, state the year / model [email protected]
  24. no if the right side works it wont be a fuse, try squirting some WD40 into the switch and switch it on/off many times to see if it clears any bad contact, Have a look at any wiring plug/sockets too, clean them up and spray those too
