xs250 brake
Wow, what a stroke of luck!
At a loss with carbs.
I'll put money on it, you have one already...a tape measure.
Jim, 1.25 inches is around 31.5mm
NHS patient records
- Just a little thought to myself...
Have you looked at youth hostels? ...They even have 240V power sockets- 6v to 12v step-up transformer?
This is my latest offering, it uses the negative half cycles from the magneto, i dont think the first attempt would work, with this one you wouvd connect the positive centre pin to bike chassis and the socket outer to -12v fuse, i am not an electronics expert so any comments will be welcome- xj600 (pre diversion) battery issue
Bummer! i am really sorry to hear that Ewan.- 6v to 12v step-up transformer?
Worth checking Merv, ive been looking at my idea and its not good, I think the foamy one is looking to use a cigarette lighter socket adapter for his gadgets though. If you are right it would be easier to chop the 12v units and wire up to new socket via a fuse to bike battery.- 6v to 12v step-up transformer?
Schematic?- 6v to 12v step-up transformer?
The mag will give out more than 6v as the revs increase, for example the mag on a 12v bike will give 50v at high revs...its the regulator that holds these voltages down, i dont know what the mag on the 6v bike will give, neither do i know of anyone doing this, or indeed if it would work, but that'd be the way i would try.- 6v to 12v step-up transformer?
You need a seperate circuit as your battery is held at 6V, I dont know if this could be done and the drawing has turned out crap, but if you have an understanding of electrical engineering, my thoughts are this, obviously it will only work when the output from the magneto is above 12v- 6v to 12v step-up transformer?
You cant do it with a transformer as such, what you will have to do is use another rectifier diode and a 12v regulator connected in parallel to your existing 6v units- me and my bike
so thats the love of your life, That reminds me, there was a post about one of them, something like was it worth doing it up, Drewpy answered it there was a picture and it was a blue one, Just a thought that it might be worth finding the post and contacting the guy who posted it, in case he decided to break it!!- 82/83 xs250 se special
usa, y'know uncle sam....America (The clue was in the dollar sign), yes you might even have to shop that far away unless youre lucky!- another carb thread - xs400
One last job before you resort to carb strip, spray around the carb manifold area with easy start, see if the engine speed changes...Leaks test!!- Battery question
Ive got a drawing from where you said, the reg/rectifier has a plug socket, the wire colours in the plug will be,White, Red,yellow/Red, and Black. so if you find a plug hanging around with these colours then thats where it should be.- Battery question
Hi smurf, dont suppose youve got a wiring diag have you?- Yamaha SR 125 engine troubles
Hi Les, Check spark plug gap, better still try new plug, then make sure pilot air screw is set right for your bike, following this it could be carb trouble.- Yamaha BW (big wheel) sand bike wanted
Dont know it but in the event you cant find one...Van Van?- 82/83 xs250 se special
I PM'd you mine and offered to do this for you!- kill switch red stripe resto
Already seen the pic's Merv, great idea and looks well!- 82/83 xs250 se special
For pictures Mark Open a photobucket account Upload your pics there with each pic you will see four fields Copy the IMG field Paste into the forum- jet needles
Nice! (good job its a twin then)- CSA forms
- Shouln't have gone to SpecSavers
Ive got to get some work glasses too from specsavers, trouble is ive lost my vouchers (but thats another story), i am so not looking forward to these safety specs, ive had them before and like you say Darren, they are the bottom of the range, i usually pay a heck of a lot of money for my lenses in order to get them to weigh something bearable, i know that these "safety glasses" are gonna weigh a ton, might have to get some scaffolding to hold my chin up - Just a little thought to myself...
