Airhead
  1. there may be a small screw behind the magneto cover?
  2. Greetings Barry, next stop pipe n slippers
  3. You used to be such a nice young fella foamy, I fear your time in her majestys forces has corrupted your mind somewhat !
  4. what part did you snap, the cable?
  5. yeah it's a 125cc single cylinder 2 stroke sports bike how we doin ?
  6. Haha Greetings ameer, put a photo up then
  7. are you made of rubber ?
  8. Greetings Charlie, good choice man
  9. Greetings Martin, 80's music eh...what 'Big Hair'
  10. is the exhaust to cylinder head joint and exhaust to silencer joint nice and tight and not leaking?
  11. Greetings Rob
  12. make sure it says Forums in your search box mate
  13. well to me it sounds like something mechanical and it's my guess that's piston and valve,
  14. try this fella http://dt125r.activeboard.com/
  15. best check the valve timing, it may have slipped? when you re-assembled it did you adjust the timing chain tension properly?? if it did slip then the piston may have had a coming together with one of the valves...hence the tapping / rattling ?
  16. trying to decypher that ! no compression...is that what you're saying?
  17. Airhead replied to gght's topic in Yamaha Workshop
    if you can keep it going by 'feathering' the throttle, then yes the idle screw needs turning inwards a little
  18. Airhead replied to gght's topic in Yamaha Workshop
    often they are set around 1 1/2 turns out, try that
  19. Well done ojm
  20. Greetings Ash
  21. Airhead replied to slice's topic in The Bar
    Get well soon Ray, what happened? Could be worse at least it's not spring/summer eh
  22. I remember you were thinking of fitting an ac regulator?
  23. take the air filter out and replace the cover, try it with it out and let us know, dont let jnr ride around all over the place like that though
