Airhead
  1. the same DT you are / were going round Ireland on?
  2. Hi Matt Yes Cynic is referring to the cylinder base gasket, it does need to be in good condition as a 2 stroke engine uses crancase compression to transfer fuel / air into the combustion chamber, if that gasket were bad then crancase compression would be less than ideal. you would not however leak oil in any noticeable amount because the oil is a trace quantity mixed with the fuel in this part of the engine. ...Paul
  3. Sorry to hear this...Try M&P, they do replacement levers for lots of bikes, they will also sell indicators I think but if you go for led ones you will need to buy the correct relay also, or maybe check out ebay. ...Paul
  4. Airhead posted a topic in General
    Hi Guys n Gals Copied from another forum... Hi All, Theres a Virus doing the rounds at the moment. If you get any emails containing - "Outlook Configuration", "BAT Configuration", "PostCard from a Family Member", "You have recived an eCARD" (they all have a zip file attached). It might be a good idea to delete em
  5. And you will see a chamfer at the ends that locates around the locating pegs in the grooves.
  6. Steve SFBrain is also predominanly on aircooled RD site, I guess the question has already been asked there....
  7. LOL...Thats older than me
  8. Haha thats not far from the truth, it even looks like my RD250B...
  9. As for the marks, they may be centre at TDC or they may be ignition timing marks, centre at correct timing and the others at acceptable + or - from correct. you can usually feel for TDC through the spark plug hole with something like a terminal screwdriver, this will show what these marks are. The carburettor, sounds like something is loose, maybe the float needle valve has somehow dropped into the bowl, hard to comment really but it looks like you will have to investigate further
  10. Yeah...Right...
  11. For Foamy I guess that would be too much info... ...
  12. His crash helmet has a row of holes running up the centre...
  13. Airhead replied to grant41's topic in Yamaha Workshop
    Also check for tight spots and stiff links on your chain, you can see them as 'kinked' when the chain is on one of its straight runs.
  14. Hi cagsy, do a search for distanzia, they will fit your 18 and 21 inch rims, welcome to the forum ...Paul
  15. Yep, you should have put fork oil in, it comes as a mono grade and is specially made for forks. They should be smooth and easy though but you have lots of travel so shouldnt be a problem although they do dive a bit under braking!
  16. Wow...Thats fantastic, wonder if it will work on a dented fuel tank. So what did you do, bung one end up and fill with water? Down Duke...DOWN...
  17. Ian cant make it next week , my eldest girl is flying the nest so it looks like a busy weekend...
  18. Airhead replied to Airhead's topic in Yamabyss
    Yep its killing me, I didnt know we had another heart in our big toes, I can feel every beat now...
  19. Airhead posted a topic in Yamabyss
    Absolutely lethal on wet smooth floors, not good when you put your bike stand down on them also. And NO I dont ride my bike in them, was just wheeling it out of the garage...Ouch.!!!
  20. Not going on my tod Ian, dunno about next week yet...SRC = SOC...?
  21. Might go over to Matlock on the old DT tommorow, anyone else going?
  22. Airhead replied to sexxy1969's topic in Classics
    Indeed it was Jim, and so was OMO...
  23. Airhead posted a topic in The Bar
    Another oldgit on the forum, happy 50th mate...
  24. Airhead replied to sexxy1969's topic in Classics
    Hi Cynthia, I found them for you Here, and welcome to the forum ...Paul...
  25. Welcome to the forum Sydney... I mean bas...
