Airhead
  1. I'm not riding my bike much....who do I tell?
  2. Does it go from the intake manifold (or the engine side of the throttle slide on the carb) to the fuel tap?
  3. Nothing there!
  4. Airhead replied to a post in a topic in Yamaha Workshop
    seems an odd one Brian, not familiar with the bike in question, how does it run before it conks out, is it 4 stroking, is the choke disengaging properly too?
  5. Airhead replied to Trim5678's topic in The Bar
    Here's one from the master but just LOOK what he's wearing
  6. Just watched the videos, what great fun! I like the headlamp idea, an on-board night time video would show it off well.
  7. Looking good well done, i think our 'Drewpy' will be wanting one of those, would be a hoot on scout camp weekends. Hows the cooling though, not a lot of air circulation due to the seat right in front of the engine, maybe a watercooled R6 next time eh? ... ...Paul
  8. Welcome to the forum c3llblock Its hard to say for sure without seeing the problem first hand, But things to check are 1: The pilot jet is not blocked 2: The throttle stop screw is not missing or unscrewed too far (This lifts the throttle slightly to allow the motor to idle) 3: Engine crankcase seals have gone, this will cause poor running. ...Paul
  9. Airhead replied to mervin's topic in The Bar
    The chemical factory i used to work in used phosgene back in the day, it usually fell to me to strip and repair the phosgene flowmeter when it packed in, It must have been because i could hold my breath the longest I can taste it now as i write this...unforgettable,,,,Oh and then there was the chlorine
  10. To repeat what I said earlier and whar racerd said to this post"What tuning have you had done" to your bike?
  11. Airhead replied to scram125's topic in Yamaha Workshop
    no one mentioned re jetting, least not in this thread. Why did you say that? re-jetting is done for good reason not for just something to try to fix 'spluttering' Having said that and to answer your question, there are several jets in your carb, the one lowest down into the float bowl is the 'Main Jet', this will have a number on it and that number gives the size of the hole drilled through it. To fit another with a different number, say a bigger number means that it will have a bigger hole through it, this means it will allow more fuel to pass through it given the same pressure differences and the more fuel it allows through the 'Richer' the mixture will be. Dont mess with the jetting sizes unless you have modified your bikes filtration, exhaust etc. ...Paul
  12. Airhead replied to scram125's topic in Yamaha Workshop
    Does it have a power valve?
  13. Airhead replied to drewpy's topic in Video Section
    I'm gonna miss this thread! When It's gone.
  14. Could be that your float bowls are not full of fuel as you state the carbs have been stripped, I am assuming this bike has a vacuum operated petrol tap (petcock, gas tap). You need to set it to 'PRIME' for a while before switvhing to 'ON' position. ...Paul
  15. i would consider letting them do it with the head on, save a lot of work, ask them about the likelihood that they will get all the swarf out, dont forget its not a 2 stroke so none will get in the bearings and the swarf will be soft aluminium so I reckon on it not damaging the bore. maybe they blow compressed air into the exhaust port with the valve open...just a thought. head gaskets are usually changed only if and when they fail.
  16. Aahh well....Just put a Garelli badge on it
  17. Whats the job then. is it remove the head, drill and re-thread and fit a helicoil insert?
  18. Sounds like the two stroke oil pump is passing, may need repairing or replacing but one thing is for sure, if you pull off the oil pipe from the carb and leave it overnight in a container, there should be no oil seepage into the container because there is a check valve in these pumps that will stop this free flowing, also check the operation of the pulley against throttle position. The over enthusiastic oil delivery will have an adverse affect on performance. ...Paul
  19. Airhead replied to wild foamy's topic in General
    Last here Oct 17th, only 2 days ago but I agree he's gone very quiet around here.
  20. I guess you would have to jet larger, if it were me I would try a couple of sizes bigger at first and continue to plug chop. jets are way cheaper than pistons and much easier to replace.
  21. 2 teeth bigger will take top speed from 65 to 73.5 mph
  22. Yep, light at the end of the tunnel now, frame looks good, a rub down prime and PJ1 frame paint or what? makes a refreshing change to the usual route of powder coating anyway Youre doing the forks now, the sliders do look good painted too, I did mine, covers up the corrosion that they almost inevitably have, quick and cheap too.
  23. Most likely culprit is the reg / rectifier unit, have you still got the spare one to substitute? there are checks you can do with these if you have a multimeter though...do a search. ...Paul
  24. Hi Phil, standard front for a 175 is 15 teeth, strangely enough standard for a 125 is 16 teeth so that is higher geared. However you can get standard +1 or +2 (for higher gearing), and aso -1 or -2 (for lower gearing) from wemoto for example, the only problem is the postal strike! Wemoto DT175MX Parts
