Airhead
  1. Diesel as has been said, it's the cheapest option. Welcome pennyless, an appropriate name to use when resurrecting an LC (you should sell it to Rich )
  2. it was probaby a vacuum line and so you would lose vacuum which would then stop the fuel tap from opening.
  3. Get a syringe, commonly found in injet re-fill kits (and other darker places), suck out the brake fluid completely. now use the syringe to fill the caliper with water. Tap to remove air pockets (bubbles) Place caliper in a plastic bag in your freezer with the fill hole uppermost so the water doesnt run out. The water will freeze and expand and push the piston out more...whether its enough i dont know, you may have to let it thaw and introduce more water and repeat. Never done this or heard it done...just a thought as this winter we have much damage at work due to frozen pipelines bursting
  4. I use 'Norton internet security' seems to work fine for me...fit and forget.
  5. Airhead replied to dargie25's topic in Yamaha Workshop
    Hmm not sure about this one, have you got the owners manual? does the starter motor work then? I will guess you need the neutral light fixing or at least have the clutch lever pulled and the side stand in the up position.
  6. Hi Anne, he more than likely got water into one of the switches, there will be a switch in the front brake lever and one that is operated from the rear brake pedal (or is that a lever too?) sorry not familiar with Aerox's. However try to identify the switches, you will see wires coming from them. When you find them give the a good spraying with WD40 whilst operating the relevant lever / pedal
  7. What year is the bike? Do you know the float height setting?
  8. i suppose pulling the choke out seems to fix the problem, yes take the pilot jet out and you will no doubt find it blocked, soak it in a bottle of nail varnish remover or as you say use aerosol carb cleaner. Dont be scared of poking it with a nylon bristle from a brush. The diagram 'Cynic' was referring to is really only for the starting circuit...ie the choke
  9. Airhead replied to root's topic in Yamabyss
    Probably not changed much with the 'field bike' fraternity, except they now have no fields left so ride on the road
  10. Not a bike that lends itself to any great performance gains through tinkering IMO, its all been talked about before...use the search function. Time for a bigger bike i think.
  11. Happy birthday Pilningas Oh and Rockerted, still riding at 70 although not on Yam's now
  12. Airhead replied to ShoKz's topic in The Bar
    It will be running better than ever When i get it running I hope
  13. Airhead replied to ShoKz's topic in The Bar
    Thats right, we cant do it. No one here knows anything about TC'c in fact we've been looking for an expert and waheyyy....you popped up
  14. Gives the motor more flexibility, better power output over the range of revs, rather than just one defined power band, at least thats my view of it.
  15. So, is the power valve the intake valve or the exhaust valve? Its a two stroke engine, the power valve effectively changes the height of the exhaust port to give maximum power at different RPM's, ie a lower port for low RPM's and a higher port for high RPM's, it mas an electrical servo motor to match the power valve position correctly to the current RPM value.
  16. Youre welcome However someone who knows more than me may add to my offerings.
  17. If you cant see what i mean then it doesnt matter, try a Haynes manual
  18. Airhead replied to ShoKz's topic in The Bar
    Yep, all present and correct, welcome back shokz
  19. BR8 is a hotter plug than BR9 so may help Here's a useful picture
  20. Yours looks nice, I can see why you recommend the guy. BUT you have to admit that your picture is many times better than his, thats just bad marketing on his part and were just having a laugh
  21. Airhead replied to jkkl's topic in Yamaha Workshop
    When it is hot and cuts out, check for spark immediately, if no spark then maybe you need a new pulser coil as these are sometimes known to open circuit when hot. Then let it cool down and if the spark returns it is more confimation of this.
  22. first ride today, only to the next town though, had a busy day so unable to go for a better ride. God it's gutless but was nice to ride even so
