Airhead
  1. Opening up a jet with a paper clip was not a good idea. You should experiment with jets of different sizes. They are not expensive. I would suggest a 220 or a 230. Abra um jacto com um clipe não era uma ideia boa. Deve experimentar com jactos de tamanhos diferentes. Não são caros. Sugeriria uns 220 ou uns 230. ...Paul
  2. Can you turn the wheel when in neutral, in neutral can you push the bike along at will?
  3. Airhead replied to 2 Wheels's topic in Forum Help
  4. OK then let's not waste any time on HELLO 1992 YZ80D Model code: 3MK4 Engine # 3MK 0005101 to 0012000
  5. haha some 'interesting' security measures here guys, would love to see them working in anger on you tube
  6. 60Nm or 43 ft-lb for an XT350 Yes I know its not one of those but its the best I can do
  7. Greetings and welcome Sarah Cold be a connection for a vacuum line, if so the line will come from an inlet manifold, It shouldnt be dripping though but the tap may need repair / overhaul.
  8. welcome mick, nice bike would like to see a pic, the only thing wrong with that model is the fuel tap, the bike shuts down completely shortly after a warning lamp comes on.
  9. Good testimony to a great little bike ric, 300 miles in a day...must have a hell of a comfy seat. YBR...does what it says on the tin
  10. Get yourself a carb balancer gauge set, sometimes called synchronising or sync...ing, bad vibes can occur if the carbs are not in 'harmony' with each other
  11. internal micrometers are hard come by whereas external ones are commonplace. You could either use the piston plus feeler gauge to fill the bore then measure these to find the bore size...or use spring loaded and lockable bore gauges which again are checked using an external micrometer.
  12. Never mind indicators its the mirrors in question here innit?
  13. Have a look in the parts manuals for download that I posted, maybe you can compare part numbers if you can find the relevant bikes.
  14. Welcome Dave of Oldham, fishing on Hollingworth lake when not riding u'r R6.
  15. Airhead replied to jebb's topic in Yamaha Workshop
    Having no filter will affect carburation, I think you should fit one or it will run lean, in the mean time try richening by screwing in the mixture screw, try 1/2 a turn out from closed for example but get an air filter fitted.
  16. Keep a check on the oil level
  17. Sorry i couldnt make it Drewpy, would loved to have seen that BSA and watched the trials
  18. Sorry i'm not familiar with the specific bike, Has something come loose, check exhaust connections, is the exhaust corroded and blowing anywhere ? is it a points ignition system, maybe new point and capacitor (condenser) are needed, also check ignition timing.
  19. lo did u have your slippers on good job the driver didnt brake hard or you'd have the pipe too
  20. Oil level ?
  21. Sorry to hear this mop head so what part of the country was it stolen in ?
  22. Anyone can post pictures in the forums If they know how
  23. 'YEIS' is Yamaha Energy Induction System A development yamaha made many years ago, some people dont think it does any good, but i think Yamaha probably know best. Also sometimes known as a 'Boost bottle'
  24. You sure it isnt YEIS ? a black box with nothing in it fits the bill here.
