Airhead
  1. See FAQ's for pictures
  2. And before this thrash check yor gearbox oil. And after this thrash check it again. Did you do the gearbox vent bubbles test I mentioned then that is a good indicator of RH seal failure and is easy to do
  3. are you re-asking the question vez? It's most likely to be a DTR eh?
  4. Aahh CT let me be the first to welcome you to the YOC,
  5. Airhead replied to Dt125.1989's topic in The Bar
    Welcome Darren, ditto the above...they are good fun. ...Paul
  6. 1: hello might have been nice 2: is the bike a dtr, a dtmx or what? you didnt say 3: you have a spark so why do you think its an electrical issue? ...Paul
  7. running without a screen is risky, now youve told me that and coupled with you tank cleaning escapades...it's a good bet there is crud and rust between the carb spogot and the carb float valve, however to sort this out you would have to remove the carb, remove the float bowl, remove the float, remove the float valve seat (the brass thing) and its gasket...and blow it back with compressed air. I have witnessed this crud in this place myself
  8. Its possible the filter(s) in the petcock are partially blocked, hence it will potter about ok but will fail with higher demand. Not sure about the CT3 but some petcocks have a filter screen within the petcock, the giveaway is a round bowl with a hexagon on the bottom. Some petcocks have a screen within the fuel tank and would need completely removing from the tank to clean. so to test just pull of the fuel pipe from the carb spigot and open the cock...good flow?....bad flow?
  9. Airhead replied to webi's topic in The Bar
    Dont know the bike well enough to say, it no doubt is black and will attach to a spigot on top of the engine, somewhere behind the cylinder, I expect there will be only one like this.
  10. Airhead replied to webi's topic in The Bar
    naturally if it's burning gearbox oil it will badly affect the running of the engine so if this is the case it's no use bothering with carb settings. as a test take the gearbox breather pipe, pour some white spirit into a clean jar and place the end of the breather in the jar also, Start the engine and look for bubbles in the jar ...a sure sign of a bad seal
  11. Airhead replied to webi's topic in The Bar
    It all depends on what tools you have and how competent you are. you will need at least a magneto puller, and decent screwdriver to remove the side cases screws (has to be a good fitting one) along with a good socket set and a reasonable tool kit. and i would be guessing if i said it can be done without totally stripping the engine...but that's my guess for what it's worth. I dont know how expensive it would be to have done at a garage.
  12. Yes that's the air mixture screw, 1 1/2 turs out is about right. should be ok now.
  13. Airhead replied to webi's topic in The Bar
    it seems it needs new crank seals to me, you smell fuel in the gear oil?
  14. Airhead replied to webi's topic in The Bar
    Yes 2wheels it's an aircooled two stroke. White smoke causes concern though, could be a sign that it needs new crank seals, white smoke can be as a result of burning gearbox oil...ie right side seal passing. Watch for gearbox oil level falling and/or smelling of fuel. Its an old bike anyway so might just be best to change them both.
  15. If I go I want a go for old times sake.
  16. Out of my comfort zone with this Steve. However if you PM me you email address I have scanned starter generator testing from my Haynes manual and I will send it you. ...Paul
  17. Granby Motors (Ilkeston) Units 1 & 2, Belfield Street Rutland Industrial Estate ILKESTON Derbyshire DE7 8DU Tel: 0115 930 0020 Tel: 0115 944 1346 Fax: 0115 944 7029 e-mail: [email protected] Sales Contact: Kelly Dunn Tom Cullen Opening Times: Mon-Fri: 9am -5.30pm Saturday: 9am - 5pm Closed Sunday
  18. I find that incredible, one of the best suppliers in the country IN YOUR TOWN and you dont know where it is!! OPPOSITE TESCO
  19. using choke from cold?...ON is lever UP ^
  20. You live in Alfreton...Granby's is your friend. Get a puller
  21. have to ask the obvious here...is the tank full, or might it have run onto reserve?
  22. Airhead replied to Vez's topic in The Bar
    I always commute by bike (or bicycle) wherever possible, however if its extremely bad weather i will use the car.
  23. Hi dave.. Clairvoyance. Clairvoyance is the art of 'seeing' beyond the five senses. Clairvoyance is often called the 'sixth sense' or esp. It is related to the images ... Try as I may I need the engine number
  24. Airhead replied to webi's topic in The Bar
    welcome in webi. ...Paul
  25. Welcome in Hobbes. I look forward to seeing the progress you make with the old DT. ...Paul
