Airhead
  1. Airhead replied to a post in a topic in General
    Link not working for me tonight??
  2. Did you check them for continuity?
  3. With the benefit of the wiring diagram now...disconnect the two pin plug socket from the flasher relay. Link the Brown/White back onto the relay. Jumper from battery Positive to the other pin where the Brown would have gone, Now try again, this takes the indicators away from the keyswitch, if it is any better you need to clean the contacts of the keyswitch or replace it.
  4. It's best to use petrol resistant laquer on a petrol tank, the other stuff disolves
  5. I would try to jumper a live wire from battery positive directly to the flasher relay signal. Cant put any detail on that until later. If it fixes it the problrm may be a dirty / corroded contact in the flasher handlebar switch. However, more likely the main keyswitch I think as this switches the battery 6V to auxilliary equipment and switches. I suppose a jumper between the red and brown may prove or dis-prove this, but again I am guessing, will check later.
  6. I imagine "Halfords petrol resistant laquer" does indeed come in aerosols.
  7. Ehhh, just how can a 2001 DTR be de-restricted "at the headlight cowl" ?
  8. Have you got a see through oil pipe to the manifold? I agree with your scepticism with regard the pump, you need to have confidence in it. Yes by all means pre-mix untill you are happy with the pump, I would think a 40/1 mix would be ok. bleed the pump by taking out the bleed screw (or rubber cap) wait until no air bubbles come out and only oil does. After that is done start the engine and allow to idle, now turn the pulley on the pump by hand until maximum, you will see the oil pumping through the see through pipe, about 6/7mm with each pulse, I think that air bubble will soon disappear If you see this you can be happy with your pump and just monitor the oil level drops in the tank...then you can add just fuel to the fuel tank next time.
  9. What is the current exhaust...standard Yamaha issue? Nothing wrong with them other than they are heavy. Like any exhaust on a trail bike though they are high maintenance and will need cleaning and painting often or they soon look sh1t
  10. Airhead replied to webi's topic in The Bar
    Hi webi, no way it will weigh half a kilo...thats only 1 lb in old money so thats mis information. We do have an expert on this bike who is a member here, he will put you righ about many aspects of this bike, he doesnt come on hare a lot though. he is 'fosdyke'
  11. Airhead replied to 2 Wheels's topic in General
    sounds good to me Kev, anything between 40/1 and 50/1
  12. Airhead replied to 2 Wheels's topic in General
    It's a 15.9 Litre tank, so 15.9/0.35 = 45 to 1
  13. Thats funny.
  14. Airhead replied to marcusrd125's topic in The Bar
    Try asking here Marcus or you may be able to pick some up here http://www.sunrisegraphics.co.uk/sunrise/index.php?option=com_content&view=article&id=22&Itemid=18 ...Paul
  15. Yes i just re-read it, and I was a grumpy old git...sorry
  16. It's an expander ring, it fits under the second (bottom) ring. you will see the bottom ring is narrower than the top one, that's because this expander goes behind it.
  17. Airhead replied to 2 Wheels's topic in General
    let's make an assumption here, that is a fuel / oil ratio of 50 / 1 Your tank holds 10 litres Therefore at 50/1 it will be 5 tanks of fuel even with an oily mix of say 40/1 it will be 4 tanks of fuel Check again Pat
  18. Airhead replied to 2 Wheels's topic in General
    I never had a problem with it youre only talking about the last drop in the tank anyway arent you?
  19. This topic was about backfire...why are you asking about brake pads? why not start your own?
  20. Airhead replied to Emzed's topic in The Bar
    Yeah your right, there was no comarison between the competition and the road bikes. When i was at school though I used to look longingly at the CZ175 trail bike,,,,aaaahhhhhhahahahahaaahhhhaha
  21. Eighteen an on a CB900, those were the days, can you imagine that nowadays? Fond memories, I had a CB900 in 1982, a black one...my first new bike.
  22. Airhead replied to Emzed's topic in The Bar
    CZ used to make all conquering championship MX bikes i'll have you know...whose showing a lack of respect now http://mysite.ncnetwork.net/jawaman/CZmx3.htm
  23. Its never happened to me so I have no experience of it, I think I read somewhere about jamming some sort of a piece of wood down there but can't remember what it was or how it worked. I was thinking though...can you fill the leg with water and freeze it in a chest freezer( spring removed and open at the top)..do you think that might get a grip of the damper tube? Just a guess
  24. Airhead replied to Emzed's topic in The Bar
    Nice intro EmZeee, a belated welcome too
