Airhead
  1. Welcome in mike, always good to see a proper intro, love your 'tools of choice', weve got fans of all your bikes on here, myself I fancy the TDR
  2. what about vacuum? runs for 5 mins as vacuum gradually builds then stops? fuel starvation? open the gas tank filler try again...blocked vent? Draining the bowl will release vacuum but fuel will still be there, vacuum with oppose the vacuum developed in the manifold. Also check the carb vent is clear.
  3. welcome to the YOC forum 4x4van, SC so you dont have much problem with rust
  4. Whats seafoam? I would use diesel oil pour some into each cylinder and leave overnight.
  5. http://cgi.ebay.co.uk/nos-suzuki-ts250-oil-pump-assembly-/370378231374?pt=UK_Motorcycle_Parts&hash=item563c434e4e http://cgi.ebay.co.uk/nos-suzuki-ts250-oil-pump-assembly-/370378231374?pt=UK_Motorcycle_Parts&hash=item563c434e4e http://shop.ebay.co.uk/bloke0/m.html?_nkw=%28ts250*%2Cts+250%29&_sacat=0&_odkw=ts*&_osacat=0&_trksid=p3911.c0.m270.l1313
  6. Post some sizes and drewpy will fab a new one from his lava lamp, or a mop end
  7. Looks great mate, off to a good start now. Whats up with the zorst then?
  8. Your bike whte tank, blue stripe...That has all the shape and style of a DT175/125MX model ask our Cynic about cobbing things in skips
  9. Yes an intro would be good Lewis > Oh and wanted ads should be in the wanteds forum. Welcome all the same, 73 DT's =
  10. I dunno mate, you'll get it sorted. By the way i'm no expert on that bike, just trying to help
  11. Airhead replied to red-butcher's topic in Yamabyss
    Welcome Oleg, we dont get many Russians on here. ...Paul
  12. Greetings szr, good luck with the sale and the search for something else.
  13. Great news mate.
  14. if you dont have a spark, try putting the front plug in the back and check again, at least you know the front one is a good one. That should eliminate a duff plug fault. place jump starter leads round the threads and connect them to a good earth when checking, or wrap some bare wire around them also securely grounded.
  15. sounds like your back cylinder isnt firing at all, under no circumstances should you be riding it like that, I cant believe you are riding it 13 miles. You should remove the spark plug from the back cyl and check for sparks, it seems there is some fuel getting there, it will go through to the exhaust, thats what you can smell. Who knows how much fuel you have in the exhaust after that amount of miles? just make sure nobody stands behind it for a while
  16. Dont use paint stripper on your plastics Liam!! Just rub them down and use flexible primer on them before the top coat.
  17. Airhead replied to tleeson86's topic in Classics
    An intro in the noobs?
  18. No...its funny though, at least you posted in the noobs, it's the ones that dont that 'pees people off'
  19. Just coz you found fluid in yer exhaust Greetings
  20. leaking head gasket? did you fit a nrw one and torque it?
  21. Airhead replied to TZR_Mark's topic in The Bar
    what do you weigh?
  22. Ha take that you awkward b4st4rd, ....just sorned it
  23. Yes it could have a blockage to the fuel feed in the rear cylinder, either at the carb or the pump (depending on the plumbing arrangement)
  24. Hi
    Airhead replied to Zsaba's topic in New Members Welcome Area
    Greetings Zsaba
