Airhead
  1. Airhead replied to Cynic's topic in General
    Cynic is in Bugbrook I'm nowhere near, good for you with cycling I love that too and there's more hill round here in Glossop
  2. Greetings
  3. Airhead replied to Cynic's topic in General
    http://www.parkrun.org.uk/daventry/aboutus/
  4. Airhead replied to Cynic's topic in General
    Well that's a big positive at least
  5. Airhead replied to Cynic's topic in General
    That's a bummer mate, was phosphate levels mentioned in your journey so far?
  6. interesting, post a picture of the bike
  7. Greetings Brett :welcome:
  8. could the crankcase be flooded with fuel due to all this trouble, how about switching off the fuel after it's started until it stalls out when everything's burned off ?
  9. Martin, I know you've fitted a new plug but try another
  10. Airhead replied to Ross1235's topic in General
    My thoughts...pass your test and get something bigger that your insurance company know about
  11. 304cc or 107 fl oz in the Haynes book
  12. Airhead replied to jimmy's topic in Projects
    Good to see the progress mate
  13. Airhead replied to jimmy's topic in Projects
    Top man Jimmy, well done you positive earth...yikes!
  14. I was thinking that 0.0003Amp isn't much of a drain too, , given that certain things are powered all the time?
  15. You know when you're trying to get top speed, at that time are you at or near full throttle? If not then try raising the carb needle if it's adjustable
  16. Airhead replied to Cynic's topic in General
    Good news Jason, me too down from 93kg to 78 in the same time scale
  17. 00G8 Sky Blue ?
  18. to the frame Si
  19. Airhead replied to jimmy's topic in Projects
    ive never done one but I understand you don't wrap with adhesive backed tape as it makes it inflexible
  20. Airhead replied to krissyg97's topic in The Bar
    looks like it's still around but you may know that? https://vehicleenquiry.service.gov.uk/ViewVehicle
  21. Airhead replied to jimmy's topic in Projects
    Jimmy I copied a building wiring loom tutorial from an old magazine catalog if it's any use pm me an email
  22. no up/down front/back movement, and i'm making an assumption the flywheel is done up tight
  23. yeah sounds like a right old bag of spanners doesn't it! The quickest thing is to do what I said it's an easy check but then there's also the con rod big and small end bearings to consider
  24. working from memory the shim will allow the swing arm to be totally free from binding when the swing arm pivot is torqued up to spec, you have to remove the damper and wheel and have the bike supported to test that, then just left and release the swing arm and it should move freely
