Airhead
  1. Airhead replied to paperback's topic in Yamaha Customs
    chances are that the next one up would do it i would think
  2. you should do a compression test Adam
  3. From a goldwing forum "Derek Hayward, a professional photographer, took lots of pictures of the recent 2011 Manchester Salvation Army Toy Run of which this is an example. You can view on his website by clicking here. You can also purchase higher resolution images from Derek by contacting him using the phone number at the bottom of the page of photos." Yup were on there all of us you can buy a high resolution print if you want...A4 or bigger Check out drewpy he's wondering where his oil pressure has gone !
  4. for now just check all connectors are clean and bright on the CDI, the coil, coil ground etc etc
  5. Ooh be careful how hot Pat, i've heard that the concave end of the can can suddenly become a convex end with that method, make it warm water perhaps?
  6. Airhead replied to freeandeasy's topic in Forum Help
    Nice intro FAE, welcome, enjoy your stay and feel free to post any long wnded stuff you feel appropriate, all help and knowlege is good eh?
  7. Right then so, I was going to rebuild my own and just buy the spokes but in the end it just didnt seem worth the bother for the price and had them done at Manchester Xtreme However I did take a few pictures for reference and to order the correct length and type of spokes. I took pictures for example this and then when I stripped the wheels I could bundle up the spokes and label them with the colours code i chose and order the spokes accordingly, take care about the amount of bend at the end of the spoke, I frogot now but it relates to inner/outer variants...BTW i tend to use paint.net to re size, edit and alter photos like this, its quite good and free before disassembly make a note of the measurement from rim to brake hub...I did a PDF drawing to give the builder, if you want Alan I'll send you it and you can check yours and amend it if necessary and enclose a copy with your parcel BTW mine still came back not to that PDF which was a bit annoying but an easy fix with just slackening all the spokes one side then tightening the other side by the same amount so also enclose a threatening letter...sure mention me! something to consider and make note of is which side of the hub is the rim info on, note this before disassembly and tell your builder to do it that way, I assume you'd want to do that so you would do this for each side of both wheels using different colour codes for all the spokes Hubs...dont bother stripping off sound paint, leave it as a primer, just rub it down with scotchbrite to key it, all other flaking and corroded areas strip smooth and prime. Top coat... well I used PJ1 satin but can you still get this stuff? I would NOT recommend powder coating, I know to my cost! Rims, clean all rust as far as possible and prime with zinc rich primer before building
  8. thats why I asked, nows the time to do it as its best done with no spokes, want to see more pics?
  9. congrats 'DirtyDT' must be a great feeling, start her early...buy Pats mini bike
  10. is your hub finish good enough NEO ?,
  11. nice intro Rick lets see the bikes then
  12. Oohh that dosnt sound good mate, maybe a new pump? Enjoyed the day fellas, especially the nice weather eh heres some pics... Kev (up yours) and Carol (Xmas Carol) Drewpy on the magnificent tracker, what a nice bike and Oh what a sound Drewpy, OldTimer and Mike (Drewpys mate) at Trafford Centre Me 'n' Rudolph S'pose thats about it then for this year
  13. I would get a new ignition coi / coils if you can kelum sounds to me that yours have 'had their day' the test is usualy checking the coil resistances both LT coil and HT coil, LT is the (orange?) to ground, and HT is end of HT lead to ground (possibly with cap removed) the problem is...knowing the spec figures . That will be in the manual?
  14. wheres all that rust gone, them stancheons have come up well, you conna drop a bit of oil in the forks just to keep them lubed?
  15. Jeez http://www.youtube.com/watch?v=rU7ki3M9QZU&NR=1
  16. know where youre coming from mate, the moby was my intro to motorcycles, had some great fun on that little thing, bought it for 50p circa 1972 (field bike) used to burn my thumb on the decompressor valve and run like fck to start it
  17. donations are greatfully accepted by the way you two
  18. Pie never mind the cat you got a mobylette
  19. greetings Chris, its unusually warm here for November! about 5C at the moment...brrrr
  20. never mind the website ollie, give Fowlers a ring tomorrow
  21. amperage doesnt matter mor to the point it is HT (High tension) cable and must stand thousands of volts, thats why the insulation is so thick. on many coils this lead isnt supposed to be removeable and is glued into the ignition coil...how about yours?
  22. petrol may dissolve the adhesive? I suppose it may last a short while if needs must
  23. try Fowlers of Bristol then ollie http://www.fowlers.co.uk/parts/from_fowlers_web.html
  24. nahh dont panic kelum, i said 'often 5000' it seems yours is 10000 resistor caps, try cutting 12mm off the HT wire where the cap screws on, (assuming you have enough length to do so)
