Airhead
  1. Greetings Ben hope you wont be disappointed with your two stroke commuter
  2. Greetings Jason
  3. Airhead replied to yammy76's topic in Yamaha Workshop
    be wary of downsizing the jet, ask yourself this...why did it burn a hole in the last piston? do plug chops to fine tune your carb jets, starting with the main jet #100 at wide open throttle
  4. from a yamaha dealer
  5. where are you?,,,you didnt fill in your profile!
  6. theres something i really like about that little thing
  7. Airhead replied to j4m1e0121's topic in Naked
    try the womans insurance company!
  8. +1 yes try disconnecting the black/white from the CDI
  9. yes Adam get a new valve bought
  10. why not just get a new one from yamaha Jams ? Try fowlers unless you have a local dealers
  11. Airhead replied to g2mjv's topic in The Bar
    does it have a fuel tap? try 'prime' position with a charged battery, if it fails again inspect a sparkplug...is it wet? good luck
  12. XS400 indeed,... just coz I like your tracker funny though i was picking my nose as i watched, up to the point it was mentioned
  13. greetings mark
  14. greetings yida
  15. Greetings bernie and welcome to the forum, look forward to seeing and reading your exploits with the XS
  16. no i mean that bracket off the headlight ears...although i'm not sure headlights have ears in oz ?
  17. very nice kinky, seen much worse, have fun restoring her. whats that structure infront of the clocks?
  18. could be water in the carb bowl liam
  19. Airhead replied to Sammyt80's topic in The Bar
    post some pics they are great events to be a part of.
  20. Airhead replied to Sammyt80's topic in The Bar
    already done mine...have a good one is it salvation army? me and drewpy
  21. yeah greetings mate, so your looking to gather up some XJ6 riders to offend...fair play to ya
  22. so we now have a KinkyDt to go with our DirtyDT to the YOC forum, how about
  23. she's going to be a real stunner ventura
  24. if its only the valve adjustment why cant you re-set them or have your mechanic do so? its no use looking at new engines just yet!
  25. so then with a 7 wire CDI you would normally have 4 wires to run, yet yours has only 3, I suspect you have a chassis ground wire missing here!...black label your 3 wires a,b, and c disconnect these wires and using the multimeter take resistance readings of these wires to an engine case screw and report back the readings
