1968 Yamaha YL-1 Oil Question
This is what i'd do if it were mine Buy gasket set first, dont tackle anything until you have one (availability?) Drain the oil remove the clutch cover and magneto cover remove the engine from frame take off the barrels, heads and pistons / small ends for inspection, check for gummmed rings and also for ring wear, decoke piston crowns and note any oversize number and mark the pistons somehow L & R fill the crankcase with diesel for at least overnight to check the crank seals integrity (important) improve / replace and faults, carefully remove old / broken gaskets place piston pins in the freezer assuming alls well with everything drain diesel out place rags in the crankcase mouth (important in case you drop piston circlips) clean off old cyl base gasket, grease and fit new one oil small end bearings and bores refit pistons into bottom of barrels but leaving the gudgeon pin (wrist pin) accessible very carefully lower the complete assembly down and fit the pin and clip ...remove rag from case mouth when clip is safely home (use helper if needed) complete final assembly etc. grease paper gaskets before installing, they come off easier and can often be used again
yamaha ybr 125 exhaust (help please)
yeah dont worry it's just doing its job, you'll only see this in cold weather
Yamaha RS200 help needed
take the pipe off the carb and see if you have a good strong flow of fuel before you do anything else, there is usually a filter gauze in the fuel tap bowl...or there could be rust in the tap inlet tubes etc etc as merv says we appreciate an intro
Hello from the NW of England
greetings Si
Hi
greetings chris good to hear you sorted it mate coz we wouldna have a clue
dan thats not quite how it works with a 2 stroke engine, there arent any passages as such, the oil is mixed with the fuel and lubricates the crank and bearings as this mixture is passed through the crankcase
Think Bike
another safety vid, quite a long one...more of a film really but great to see these old ones eh and full of relevant info #!
there is normally a screw in the top of the pump, remove the screw and oil will flow out, replace when the bubbles (if any) stop
- swearing in 1811
- Foamys new toy :D
Woohoo got my pinkie
well done, does the tester still jump out in front of ye?
The Regular Birthday slot
happy birthday jason
- hello from the western isles and the owner of the most rotten ty in the world!!
DT125R
1; possible blocked pilot jet 2 How many miles has it done then?
And So It Begins,,,,, Mini Bike
nearly done pat...soon be mini bike.....'THE MOVIE'
- Mechanic
1978 Yamaha XS 750 ruff running
you need to balance the carbs before you can comment about rough running really...see the manual
need longer brake cable sr250
That'll be because its too short
Last year's milage
no idea mate but didnt do much meself
Ybr 125 key not turning, Cant Start her up
get some WD40 in the lock to displace the water
Need experienced help !
by dirtbike what do you mean exactly, it'll never really be one, the geometry is allwrong, its a trials bike...made for climbing walls. would be much sought after here in the UK But not in the US?...no interest in vintage trials there then?
My new project!! - Honda VFR400 NC30
nice one vic, now for the big spend lol, yeah those TT legends look very tasty dont they
Doreen's Story
- Newbi Saying Hi - 1997 Virago XV125
Greetings Greg...nice find just check there arent any 'frozen' links in the chain and get it well lubed up, dont be covering her in salt now- Gunk comin out of over flow pipe
affirmative then, water pump seal - Newbi Saying Hi - 1997 Virago XV125
