Problem replacing my TZR50 original exhaust
DEP is make of a popular after market exhaust often fitted to DT125R's
just remove what you can and blank off the pipe, it's to do with emissions. DT125RE's have this thing also and they have to do this when DEP exhausts are fitted...I have sent you a PM
1972 G7S help
Change the battery, i'd put money on it that it's no good from your description of it. Buying or finding the meter would be a good move also, then when the new battery is fitted you can check it's charging by measuring the voltage increase with engine running.
barn find
what about the cleaning !!!???
First Time Project (YBR125)
unscrew the screw by about 7mm but leave it in, then tap the screw back into the bar end, keep it pressed in to the bar end and try pulling the thing off like that try posting smaller pics it takes an age to load and edit your mega mega pixels!
Yamaha Tzr 50 fairing brackets
yeah its annoying when posters dont follow up what they start!...not been back since Sept 2011
Will we ever see dust again,,
nope they have written off May already :( :(
Just joind so thought i would say hi
Aye most of us just tell her ask her nicely if we can have another bike...like your style 'icedragon' Greetings and
Hello again, i might be back
Welcome back Dan
YP250 weave
check tyre pressures steering head bearing play wheel bearing play suspension play
Noob Alert!!!!
Greetings JaK and
Ok..Ok... I'm Busted! (lol)
Greetings David welcome to the forums
Its wet and bloody freezing here
Hello!
Greetings OS nice bike the YBR, how does it perform compared to the R125?
Hello
Greetings DF , your bike looks mint
DT175E sudden stoppage
wow...you've got a door to Japan
Id year by engine block number
I wonder if forum member majormods will know? he's a dealer in US so might be of use?
when you say 'The Block' are you quoting the number from the engine case, not something on the cylinder barrel?
sr 125 performance
or two..a 106? thing is it WILL apparently run ok with the 102 but it will no doubt overheat and may burn your exhaust valve
I think they are being a bit 'generic' saying VM24 - 44, the carbs are made specially for yamaha model specific, i'd buy the next one bigger...than? did you try raising the needle yet?
DTR 125 COIL
Test with a multimeter NEV, are any of the spades connected to the iron core (no resistance)? if so you can either attach the black wire to this one or just not bother and rely on the mounting bolt...or both
Although it's almost over - Happy St Georges day to all from England
Cheers mate, have a good one yerself too
2002 DT 125R HELP!
FFS!!! Check the magneto rotor hasnt come adrift
DT 175 MX 1978 Start up problems!
Can i be frank...It's Paul Pete
Help with problem???
is your chain loose, worn out, sprockets worn (front and back), teeth missing??? ...all generally neglacted and sad If the answer to any of this is YES you are risking personal injury or worse god forbid because if that chain breaks you can suffer serious injury! and engine case damage
