Airhead
  1. has it got a sidestand switch kelum?
  2. did you check your power valve is set up properly to fully open?
  3. thats all you have to do ben
  4. Have you ever had the magneto rotor off? If so did you torque the nut up to the recommended specification? A rotor nut not torqued up properly will shear the woodruff key and render the bike sparkless!
  5. Airhead replied to jimmy's topic in The Bar
    mines still going strong, 40000 miles...1979
  6. yeah fix em both if you need any help...just ask we have a few USA DT owners on here who i'm sure would be glad to help out too
  7. my guess and that's all it is worn piston rings causing blowby and pressurising the engine block? But of course you should check the oil level is correct
  8. Thats how the fight started
  9. see my pinned topic in the dualsport section
  10. sounds like it's seized to me too. What exactly is a postie bike then?
  11. hissing is normal paul, try another spark plug
  12. I found it nigh impossible to torque every nut on mine due to various gubbins in the way, so i torqued the ones i could and did the others by hand
  13. 1993 XJ400L me thinks
  14. is it possible to change this speedo then? or is the bike an import and no such change feature exists?
  15. is there slots in the maneto flywheel...any chance you could spray through the slots? spray WD40 at the seal when the engine is running...listen for a change in engine speed / tone to test the seal
  16. isnt the SRX a single cylinder bike? that looks a bit like a diversion or summat!
  17. you will need to open a photobucket account for yourself, upload your pics to your photobucket account, then you will be able to post them here...it is well worth your while learning how to do this because questions can sometimes be so much clearer when backed up by a photo see the FAQ's sub forum in 'New Members' for more explanation
  18. which side smokes more...the right (clutch) side ?
  19. i think you will find that some of the spokes get in the way when tring to remove others but im not talking from experience here. I you do strip the wheels down entirely dont forget to note down the offset before you start
  20. Greetings Phil and it will be interesting to see you sort the old DTMX out...well to me it will post up a
  21. Happy Birthday blackhat and yamahead
  22. kayos did you get her going?
  23. Neil i'll have to ask the obvious question here...If it's too wide leave it at the dealers untill the gate is widened?
