Yamaha Dtx125 vmax 90km/h
It may be 210, you will only know by checking it, try a bigger one but I dont know how much bigger...I would try a 230 or 240 it's better to be too big than too small! ???
Well did you fit a bigger main jet in the carburettor...what size is in there right now?...with that new exhaust I would fit a bigger one also there is a wire connected to the CDI that will require earthing to the chassis or battery negative, this wire goes to one of the plugs at the speedo, it is black/green ...make a connection from this wire to chassis. This should have great effect. Dont forget though...fit a bigger jet in the carb or you will be back with photos of a melted piston!
Thats OK emilz just as it should be Now you have the exhaust off, is there a restriction tube inside the neck of the pipe where it attaches to the cylinder?
sorry emilz dont do skype
XJ650 fuel/power issue
Hmmm so perhaps it affected the mixture this change in filter 1: did you oil the filter? 2: Did you reset the carb mixture screws? Try turning all the mixture screws anti-clockwise about 1/4 turn (90 degrees)
The hole is there already. I can see it in your picture
1 Turn on key 2 zzzt zzzt (PV cleaning cycle) STOP 3 'U' notch in pulley (1) aligned with 4mm hole (2) clear picture of 4mm hole (2) 4 Take off exhaust pipe 5 see the top of the exhaust port...it is smooth. The PV is open wide
Yamaha TDR125 Exhaust (dowpipe) where do i buy one??
It's great bike but not a great seller so finding a good used one will be hard!...worth saving a search on fleabay though
just when you think it cant get worse.... your clutch goes
yeah if you oil the filter it will run even richer but it should be oiled anyhow
does your power valve open fully emilz? when you first turn on the key the PV should make a noise zzzt zzzt (the cleaning cycle) then come to rest with the notch in the pulley aligned with the 4mm hole in the cylinder. At this point if you take off the exhaust pipe the PV should be fully open, see the top of the exhaust port...it should be totally flat with the PV...
Sam buy your jets from allens, they are genuine ones not pattern...so you can trust what it says on the jet, might be worth buying a few different sizes they increment in 5's at this size http://www.allensperformance.co.uk/
check your air filter isnt ripped or has holes in in puma
Heres My RXS100
last time he was online here was june 2009 so you wont get a response
idiot van drivers
you should check your bike out bippo, those spindly forks will be easily bent!
Yamaha DT125RE restoration derestriction catastrophe!
when I wanted a colour match (aerosol) I went to my local motorfactors shop and trawled through their many colour chart books for old cars, comparing them against the colour of my original painted petrol tank. When I found something to match they mixed it for me and wrote the code on the can for future ref
XVS 125 Dragstar problems?
If the yamaha mechanic says the rear cylinder is low on compression, then thats the thing to remedy first isnt it? how long have you been riding this bike has it ever performed well when did it stop performing well was it a sudden change you want help...try and give as much detail as possible...always! aside from that...needing choke in order to 'rev' the engine could be an indication of a blocked main jet in the carb so it's worth checking that one out
Broken down at the side of the A1 :o( XJ600N
If it's charging I would say the battery is in fact... 'gubbed'
1970 DT1 Oil Seal replacement
Never mind the bike Roger, cant you get yourself sorted out
DT 125 R 2003 advice needed
yes you'll find something in here
Hello
Greetings puiforcat
Hello all :)
Greetings Marcus
ZA noob reporting in
Greetings Jon from ZA
Just got some BT 023's. Anyone running them?
They are good tyres DirtyDT I had them on my bandit until recently, now I have michelin pilot's on
Yamaha xt 125 x digital speedo not lighting up
I think we are misunderstanding each other here, I am saying that egghead should check the power supply to his dash before he spends £££'s on a new one
yeah it looks very nice too grouch, but I was meaning egghead...before he shells out the readies, it might have no supply...is that possible?
