Airhead
  1. why not just put oil in until you see the level in the glass jimmy?
  2. cant see it being very fast or powerful, crikey the speedo tops out at 50mph, must be restricted some!
  3. painting the sump guard will be easy, yes why not freshen it up at at point of sale, maybe the exhaust too it's your call
  4. whatever you do welshwan dont expect it to last, you just have to do it again when it starts rusting, i'm afraaid that a that water being thrown at it when it's hot takes its toll, It's an every year job really I have found but ignore it at your peril
  5. Greetings and
  6. I'd see if the switch contacts can be parted, maybe the fault is there
  7. so tell us more...is this a bike you recently bought and it never worked right, or one that worked just fine and recently failed? whats wrong with the switch as you see it?
  8. chances are then that someone fitted the wrong switch so you have lost some functionality
  9. yeah that might be the problem Ken
  10. splined shaft? not on a brake pedal that would be a gear pedal Ben yeah as said I persnally ride with the ball of my foot on the rest and slide my foot forwards to brake. Well done on sorting the adjustment fella
  11. I'll have a look at work tomorrow, we used to have one but I think it went missing, I'll check anyway
  12. it will work thats what its for, they have a tapered knife edge and they bite in behind the bearing and move the bearing along the shaft
  13. you need acess to a proper bearing puller mate, local garages?? is your 175 still in bits? http://www.google.co.uk/imgres?q=bearing+puller&hl=en&sa=X&rlz=1W1GGLL_enGB401&biw=1024&bih=516&tbm=isch&tbnid=OeJ6ON3Gw_lc5M:&imgrefurl=http://export.rsdelivers.com/product/rs/da4098/hydraulic-bearing-puller-set/3497249.aspx&docid=IM9TWXYz1ljS_M&imgurl=http://media5.rsdelivers.cataloguesolutions.com/LargeProductImages/R349724-01.jpg&w=444&h=346&ei=yns8Ue-hB_GP7AaIsoDABQ&zoom=1&iact=hc&vpx=499&vpy=157&dur=2672&hovh=198&hovw=254&tx=125&ty=115&page=1&tbnh=135&tbnw=173&start=0&ndsp=12&ved=1t:429,r:3,s:0,i:103
  14. Nice intro Dave
  15. If it only leaks when you push the bike in gear it may not be the float or needle, if youre lucky it could just be a blocked vent tube...try pulling off the vent tube from the side of the carb and test if the problem is repeatable
  16. no need for primer, chances are the primer (unless VHT) would burn and take the top coat with it! No point in removing sound paint at all, just 'key' it with 320 grit paper I always do the rust removal then treat with jenolite the rusted area, then paint the rustad area with BBQ paint, allow to dry then do the whole lot again with BBQ paint
  17. plastikote BBQ is recognised as being cheap, easily available (wilkinsons, B&Q) and good for the job, best left to cure as preload said or it will burn/flake if rushed into service
  18. very nice ausibatla
  19. That nipple is at the bottom of the float bowl right? If so It's the bowl overflow and you should check your float height or fit a new float valve assy
  20. It doesnt help wih having the exhaust hanger bracket in the area...It's there somewhere and I would imagine it's an M6 bolt (10mm spanner size) at a guess
  21. youre barking up the wrong tree Ben, The thing with the split pin...isnt that the pivot shaft for the pedal? and the thing with wires is the stop lamp switch when you eventually get to the bottom of this you'll have to adjust the stop lamp switch or the lamp may be on all of the time
  22. Ben, the brake arm stop is usually a bolt with locknut, If you lower the brake arm in this way you'll have to slacken off the adjuster again at the end of the operating rod first, and re-adjust as reqd later
  23. see screw 16014 Davie, when you screw them fully home...Thats a gentle fully home mate...no force
  24. Nahh screws in the bottom of float bowls are for draining usually, often there is a spigot there too where the drained fuel will exit
