Airhead
  1. we never got that updated model here in Europe, by 1984 we had moved on to LC's so on the model we did get...there is no need for said T handle, we just unscrew the allen screw out of the bottom of each fork leg
  2. Airhead replied to mike1949's topic in General
    thats where i live
  3. Airhead replied to mike1949's topic in General
    good find mike, bet you'll be back there sometime
  4. Its only on the RE version mate
  5. MOT
    Airhead replied to woodburnyq50's topic in Yamaha Workshop
    not sure but i would guess no, I know for a fact though that a pair wouldnt be needed
  6. see here nicsy and feel free to post a little intro in 'new members'...Thanks
  7. Greetings marshie lets have a look then
  8. Airhead replied to AndrewElvisFan's topic in The Bar
    Havent you heard ian...It's 70 now fella
  9. wow thats a great find slice, cant wait to see the pics
  10. Airhead replied to drewpy's topic in Projects
    looking great drewpy...keep the momentum up love the handlebar how was the kicker you picked up from Stafford then?
  11. There is a polished ring around the circumference of the flywheel rotor! is it rubbing on something...rubbing = friction = heat ? how did this rubbing occur?
  12. yeah check the ohms value of the source coil and pulser coil and compare them to spec usually + - 10% specs in the workshop manual and sometimes in the parts book under 'Service Data' also the ignition coil (HT coil) can be checked against spec in the same way Yes the source coil is power and the pulse coil is trigger for the ignition is the HT cap to HT lead connection good? I'd try a new cap and cut 10mm from the end of the lead and re-make that connection...caps are usually 5k ohm but again that will be in the manual
  13. n i'm not familiar with the bike ade, nor do I have a wiring diagram to refer to However, the bike is a single cylinder so it will only have one pulser coil...the other coil being the 'source coil'. is there a brown wire to the CDI? brown is often the switched live on these older bikes but not sure about yours the collection of wires to the stand, clutch and neutral will take care of the safety interlocks, the ignition will be cut if put in gear with the stand down...maybe not if the clutch is pulled but I dunno about that black wires are chassis or -ve and perhaps each of the engine coils have a black connection?
  14. wow thats a really comprehensive intro 'm' Greetings and to the YOC..cant beat the 2T's they're such fun
  15. Airhead replied to jimmy's topic in General
    Happy birthday merv and a belated happy birthday preload
  16. whats is it like with choke on...any better?
  17. greetings Sue , whatever it is ask away in the appropriate forum
  18. Airhead replied to Tfk13's topic in Yamaha Workshop
    you have PM
  19. post pictures emil, it is hard to make any judgement without seeing what you see yourself
  20. Airhead replied to mucker1983's topic in General
    happy 30th birthday mucker, my bike is older than you, maybe my underpants too !
  21. yeah barb maybe your spring has been strained it isnt normal in my experience to have to turn them more than about 1/2 turn as you say. The clutch plate springs should do most of it though so i'm wondering if there is something stiff or the cable not routed right as well?
  22. cant see you needing to wrap it back anything like the amount you are saying, secure the fixed end into the case? then just hook the moving end over the arm...that's it
  23. Airhead replied to Tfk13's topic in Yamaha Workshop
    will have a look later
