Gear change issues - DT175
sounds like clutch slip check the adjustment it may be out
DT175 blowing bulbs
the regulator and rectifier are different units.. The regulator is an AC regulator and will stop the headlamp bulb from blowing, it does not stop any of the other lamps from blowing...a good battery looks after the rest of the bulbs
DT175 Flooding
wont do you any good that one, just have a look yourself...use a magnifying glass if needs be
Hey Guys
Greetings anzi
New member
Greetings Grahame
After 30 years............
Greetings John I was wondering why you chose that moniker...Thanks for clearing it up
newbie
Greetings lantus, yeah thats a great benefit eh, oh and the fuel consumption on the ybr too eh?
- Defecting!
is the clutch adjusted correctly?
DT175 Flooding
you'll see if the needle is worn, there will be a visible wear ring around it
rowdy at the pub!
They do look good I must say,
rowdy at the pub!
enlighten me...FTO?
rowdy at the pub!
Ohhh the suspense is killing me wacha bought this time foamy
DT 125R does not idle, why?
best bet is to disconnect it from the throttle control and the check it takes the easiest route from the cable splitter back to the throttle, then re-connect it. Make sure theres no sharp bends or kinks
yes but only if thats where it snapped...at the throttle control
Newbie getting the beers in
yep...I understand that dishwashers are good for cleaning all manner of things too
Greetings grumpy post a pic then
could be a blocked pilot jet? or of course how about a badly adjusted idle screw setting...try turning it in (clockwise) 1/4 turn at a time
Bought a French Virago XV125cc
Google translates FR to En with some degree of success http://translate.google.co.uk/#fr/en/
DT175MX Magneto Upgrade/ Replacement
they run perfectly well with the original magneto / cdi setup Not worth £££'s to change IMO
Highly skilled Excavator operator
wow
Rebuilt Carb start up problems
It shouldnt have climbed to 8k revs! is the throttle slide in the right way round wih the cutaway facing the air filter box?
How to repair/check the speedometer setup on a DT175?
yeah just had a look in the parts book, the bit with the arms on they call a clutch, I assume it has some flats inside the hole through the middle which locate on flats on the gear, and the two parts are held together by a circlip ? with this in mind surely you can see what the problem is here! dont forget the arms of the clutch must go between the raised out sections of the wheel hub so that it can be driven by the wheel's rotation...so offer the brake plate up to the hub correctly
Think your insurance is high?
Wow...I'd frame it
yes its a 1 piece assembly I think
