Gilera 4V project
isnt there lines on the rotor and a mark on the casing?
Gilera 4V project
That head has an awful lot of finning looking great mate
DT175 running on choke only
Not on these carbs John, dont have to risk it
DT175 Flooding
I can understand your concern ...just do it with the jet still in there, why not? you should still see the fluid coming through
DT175 Flooding
use a straw on your carb cleaner aerosol to spray back through the two holes in the diagram and witness the cleaner coming through the pilot jet
if you couldnt get it out but can see light through it the jet must be clear but how do you know the little passageway is clear through to the venturi? did you spray carb cleaner down and witness the passageway is clear?...see the diagram I posted in your other thread
DT175 Clutch Adjustment
I answered your other post! before I saw this one not good is it
Done a phoenix
I remember ya Dave, welcome back fella shades of the past
you double posted this...tut tut!
Gear change issues - DT175
yes quite likely Slacken off the cable adjuster Take a hold of the push lever at the engine and push it forward until it resists movement At this point the pointer on the end of the push lever and the pip on the casing should align, use the adjuster in the centre of the pressure plate to achieve this alignment Now adjust the cable adjuster for approx 10mm of free play at the end of the lever If the alignment of the pointer and pip is not achievable, then check the wear of the plates by measuring them with a vernier caliper and referencing the specified thickness and wear limits in the manual
Range Rover Drives over bikes and is chased down
Feck me, this got me going!!! http://api.viglink.com/api/click?format=go&key=bbb516d91daee20498798694a42dd559&loc=http%3A%2F%2Fwww.the2strokeforum.proboards.com%2Fthread%2F8901%2Flandrover-runs-bikes-chased-bikers%3Fpage%3D1%23scrollTo%3D95630&v=1&libId=9e6730e2-ffed-45f7-81b8-b1d84a21be1d&out=https%3A%2F%2Fwww.facebook.com%2Fphoto.php%3Fv%3D153102431566769&title=Landrover%20runs%20over%20bikes%20then%20is%20chased%20down%20by%20bikers%20%7C%202strokeforum.&txt=www.facebook.com%2Fphoto.php%3Fv%3D153102431566769&jsonp=vglnk_jsonp_13805753275936
One of my fave tunes
just how do I embed it...cant seem to do this any longer...I used to just copy and paste the youtube browser but I doesnt work any more?
- FS1E Custom?
- Epoxy carb float repair?
petrol disolves araldite i'm sorry to have to inform ya of this- New Member
- Gilera 4V project
Still dont see why you believe this to be the case??? normal engineering practice is to pull/push the shaft through the bearing,- Gilera 4V project
you need to be careful here mate, the bearing should be in the case and not on the crank before any attempt at assembly, the same thing sometimes happens to DT's whereby the bearing stays on the crank during disassembly but It's not supposed to be that way!- 1998 SR 125 starting issues
yeah you should do a good job with sorting out the exhaust next as it may contribute to the problem- ~~Daily Feed, post what made you laugh today ~~
1st Day Back at School Attendance call on the first day back at school in Birmingham , UK . The teacher began calling out the names of the pupils: "Mustafa Al Eih Zeri?" "Here." "Achmed El Kabul?" "Here." "Fatima Al Hayek? " "Here." "Ali Abdul Olmi?" "Here." "Mohammed Bin Kadir?" "Here." "Ali Son al Len” Silence in the classroom. "Ali Son al Len" Continued silence as everyone looked around the room. She repeated, "Is this the name of any child here?" A girl stood and said, "I think that's me, Miss. It's pronounced Alison Allen"- 1998 SR 125 starting issues
OK then, elec start only...It may benefit from a bump after squirting in a little fuel (10cc) or charge the battery fully and try the button- Hello
try squirting a bit of petrol down the plughole, see if she catches maybe try a bumpstart too...it should be easy enough on that bike? edit...I'm not familiar with the haves and have not's of every bike of course...is this one elec start only?- 1998 SR 125 starting issues
Hi Graham, so how do you know you have the fuel ingredient...is the plug getting wet with fuel? Taking apart the fuel doesnt mean It's getting in the cylinder if theres something wrong with the supply,,,Filters...Fuel tap etc- Hi Guys
Better late than never Chris, the little YBR is a great choice 1st bike Greetings and
