		Done a phoenix
		Hi dave " i remember the annogram . I "v got the union flag , as thats what we are,,,
		DT175 running on choke only
		Presumtion" the mother of al f*kups, that pilot must be blocked,,,Its the pilot that takes the throttle first,, as venturi speed rushes thru - then fuel is drawn thru main jet bye the needle, only when wide open [ throttle] does the size of the main jet become important,,,
		DT175 Flooding
		She run when choke on " if you take off choke and it dies, the pilot jet is blocked, remove it , And clean . till you see thru it,, side holes too. You say " properly" do you mean it runs but not good enuff without the choke ? if so its lean . Thats why richening the mixture [ choke] makes it run better,,
		Range Rover Drives over bikes and is chased down
		sCAREY" for all , humans can be so cruel to one another,,
		FS1E Custom?
		Looks like a baby SR , , are you saying --- newman
		Bit of trouble in the road! Any idea's?
		It had been clunking for a while,, .i would be checking wheel bearing/ swing arm worn/ sprocket carrier bearing,,,
		DT125r Deristrictions and Mods
		If you jam open the P.V. ther will be no bottom end power , you"l have to slip the clutch at lights, . P.v were invented for road biast 2 strokes, As old race 2 stroke engines have large exhaust ports,, power is all top end, The YZ125 motoX er is a fine example . As for jetting ,,,,thats suck it and see = plug chops,,,
		off roading
		You"l be issued with an A.S,B,O . very popular things in twatsville ,, i believe
		Gilera 4V project
		hERE " I Used a concrete core bit,[ cut down ] to pull the TS250 crank thru, skip to rebuild part of vid,,, http://www.youtube.com/watch?v=vVKeT8Mh2dQ
		Gilera 4V project
		Hes slower than a 4 stroke tommy " Drwewps i"ll find video of the tool, , yeh pull crank thru casing ,,,
		dragstar 650 1999
		Thats a shure way of blueing selector forks,,,,as you apply pressure, the drum will start to turn = selector fork rubbing on gear, Try shifting up without clutch,,, as there is no syncromesh. in bike gearboxes, Once selector forks are blued [ burnt] they will wear to the point they"re thin , resulting in sloppy changes , and jumping out of gear,, http://www.youtube.com/watch?v=vq11CusULlk
		Can't kickstart my XS360,  no piston movement
		Gas in oil. sounds like the petcock is leaking = filling carbs and running into cylinders. watch for hydrollic lock, this would jam kickstart, and bend conrods, .take out sparkplugs . and turn engine ,
		'94 sr125 speedo problem
		Like fomeh" you mind is never above the navel .... -----------------
		xvs950a accesories
		Hey lallasro" these would look real cool... http://www.ebay.co.uk/itm/VISTA-WATERPROOF-BICYCLE-CYCLE-LUGGAGE-PAIR-PANNIERS-/280700912976?pt=UK_SportGoods_CyclAcces_RL&hash=item415b140550
		1976 DT175C
		Shes up and running,,, sounds sweet too.....
		You mean wheel bearings " just check they aint rough when you spin the wheel, any grinding noise , then yeh,,,
 - Cat vs The paper army
		Pilninggas' new toy
		I"v just sold my cruisery kinds muscle bike,,,it was an inline four,900cc. guy picks it up tomorrow,, Bye bye,,,iliminator..
		Pilninggas' new toy
		Thats cool merv" i like the colour,,,
		Yamaha RS200 worth keeping
		I doubt Fomeh" has not seen this post .... -----------------
		Aye andre" usually access from other side of hub, Circlip- thrust washer-speedometer drive plate- [ your is broken] -speedometer drive gear, . in that order,
		Wheel codes,,,DT/ CT ...175
		Have a question on wheel codes,, 185-18-50-204. Takasago... the other,, is 185-18-3K-204 Spill the beans Annorack"s Whitch models ,,
		Hello. Looking for Opinion
		Don"t forget the DT400, more torque , but only a slight bit faster ,
		Hi yas " if its original" yeh keep it safe ,and dont restore, as unrestoerd [ good nick] is worth more than restored models,,, somone will relive there youth an lust after it,,, Best do an introduction in members section ,,, keep the wolves happy,,,,
		First time here  New memeber
		Yeh dave " the more heads the easier the problems solved,,, welcome in
