blackhat250
  1. Welcome inn claude "
  2. When the engines at idle , and you rev it , is noise still there ,?
  3. Hi Karas " theres a few DT lc owners on here , advice will be along soon,,
  4. Look like extras from DR Who,,
  5. Thers a YL 1 ON EBAY,,, I would post a link but .................... UK bike,,,not an import,,,, rusty ,,,,,
  6. blackhat250 replied to blackhat250's topic in General
    Good find Capt" its I.Explorer 11, site Admin need to add that Workaround [ link above] to make site compatible ,,,
  7. blackhat250 replied to blackhat250's topic in General
    Am on Internet Exp, 8.1- 64 newman, " will check add on[ enable]
  8. blackhat250 replied to blackhat250's topic in General
    Ok .enabled most script, including clipboard access . still cant post a link, on here, I can on the 2stroke forum and DT forums, theyre Plusboard format,,, I get a box [ bottom of screen on here,] add on failed to run,,,,WTF is that
  9. blackhat250 replied to blackhat250's topic in General
    That's above my heed Capt" am on Internet Expl, ,last time [ old computer] I downloaded Chrome . and a load of pish came with it [ Adds etc] , this is a new Desktop , and am keeping it clean , I only downloaded 8.1 as it said it was an upgrade, huh,,
  10. Hi Afool " missed this, Standard is 634.[ 70mm] Look at F,A.Q"s to see how to post pictures, If they"ve been bored, they only have an arrow at front & 25/50/75- or 1.00 at the rear of piston crown, [ that's on N.O.S. pistons,] aftermarket may be different,,
  11. blackhat250 replied to blackhat250's topic in General
    aHA" I did the bbcode , then Quote,,, no Smileys now tho,,, Even if I edit the post,,,bah,,
  12. blackhat250 replied to blackhat250's topic in General
    Am the same with the Quotes, it just does a normal reply, If I try to add a link, or picky , A big dropdown box appears, with sections to fill with URL- Anchor site- Email Add, . if I try to close it I get another box pops up ,and cant close either, results in I have to close the page,,,,
  13. blackhat250 posted a topic in General
    Right " I cant post links or piccys or quote on this site anymore, This all happened after an update [ 8.1] I can post on any plusboards style Forums, So is it my cookies on here or what, ?
  14. The neutral light is worked by the detent plunger, it earths and light comes on, thers a small switch [ near front sprocket ] you should see the wire /connection, , clean this first, do you have a manual, ? 12.6 at idle and what volts if revved ?
  15. blackhat250 replied to drewpy's topic in Projects
    Will this change ride height ? is the R6 unit firmer ,?
  16. That's a right posh accent you have, soond like Uwan Mc"gregor ... Whar you from kelvanside , or Creiff
  17. blackhat250 replied to drewpy's topic in Projects
    Red eye
  18. Engine Ice , I think,,,
  19. Nice ride N,S,D " I think that be a the restriction notice, [ for a rider on mod 2 ] down to the required BHP.
  20. Hi sam , you get a clutch tool , or an air gun , , you-tube has yz250 tear downs , similar to the DT,
  21. Hi luke, they never asked for proof, , anyway your a member now,,
  22. Had a run on a Burgman 400 few years ago, I just didna feel safe, I think it was the small wheels
  23. Whats on it O/J " , what happens is the wider tyre squeezed on to a narrower rim ,makes the tyre more pointed in the centre, Seen questions on other forums, folk trying to put 190s on a 5.1/5 inch rim [ designed for 180] and its steeper curve make it handle worse,
  24. blackhat250 replied to drewpy's topic in Projects
    What a plonker drewps
