blackhat250
  1. Aye vin" they do come up now and again, the rarest part is the small triangular gusset [ mounts numberplate bracket ] The fsie numberplate bracket is the same, thers repro on ebay, the fronts are on yuni-parts [ ebay] the stays are different on dt"s 19 inch & 21 inch front wheels , the muffler is same as DT125 twinshock, not the DT100 tho..
  2. Cool " in the black ,,,
  3. Welcome jamesie" See you got a DT too, , Pickering " av been there on way to hart beat ,
  4. Hi vinney, I had a DT175C brand new in 1976. white/red. yours be a yank blue is it, pop up picky .
  5. Hi chalky " that's a trick lookin thing, how does she go ?
  6. Hmm " When you switch on ignition, does it whirrrrrr, [ thru cleaning cycle,,] ? Do an intro , in new members, ALSO
  7. Ah I get yeh , that pipe on 350"s , was this labelled "balancer pipe " ?
  8. Hi matt " it will all flow in time ,,, hows the divvy.
  9. Ah" but wot actually does the boost bottle do induction boost ?
  10. Tidy luke " was it cheap. and flatter yeh, them are high bars,,
  11. Wheel must be outa line , [sprockets] how come the sudden slackness, was wheel not tight, /?
  12. Brilliant , 1980" s Sierra went by, and 1990 fireblades, must be auld
  13. Bunch of Squablers I"v heard , I was there in 2010. , great setting,,,
  14. Looks superb . . What does that boost bottle actually do ? And how does the clutch stand up, this where the next upgrade Is usually
  15. Evening Kon " , member jimmy will highlight all that's good about the XS250, , As he owned one in the 70"s,
  16. Am with Lallasro " its a set up. for big hits on u-tube / viral thing,,
  17. blackhat250 replied to <Dick>'s topic in Yamabyss
    Joey Dunlop story on after it,,
  18. We were In fife on sunday, Falkland/ kennoway Pitinweem harbour, , 3 of us on 2strokes , Head for Callander ,Aberfoyle - Dukes pass , great roads .
  19. Bonnie machine, , whar d"you byde ? what roads were you on at weekend,,
  20. Great job there, very neat.
  21. Hi rick " how"d they manage to bend the frame, ?
  22. Blocked oilway " = lack of oil changes, dirty sludge,
  23. The choke aint working then, and if it don't idle, then the idle screw must be the wrong one, [ if it does nowt] take it out, check it, take off carb -and looking thru from rear, screw idle screw in, it should lift the slide, , get that pilot out , it cant be clear, The choke well [ in float bowl, ] needs cleared, blast it thru, should see fluid come thru small hole
