blackhat250
  1. Hi nottslad, Ebay is the big shop window nowadays[ expencive tho ], but ther is bargains on Gumtree,
  2. Welcome criss, fire questions in workshop, ...
  3. WelcomeV.J " how hot is it over there , great biking weather i bet,,,
  4. Welome criss " yeh get involved, any input will be helpfull to others,,
  5. Welome brett" another SR, there popular at the moment,,, saw one tonight in town,,
  6. Sounds good Dirty" i"v dropped to 195 main jet, better now too, Was bogging on W.O.Trottle on 210 jet. i have a slight knocking on excelaration, like detonation, its smooth at cruise speed, and ok if gentle throttle openings,,,timing maybe,, it on the mark, [ cdi] , R/h crank seal on TS250 is behind the main bearing, r/h bearing is lubed in gearbox oil, this explains only 1 oil feed to L/h bearing, ingenious , but a pig if seal needs changed,,
  7. You are naughty slice " i fixed it for yeh,, ,, Cheers boys, ,,,,,,,,,,, Ok pete,,,,, thaks mate, i cant believe we live 5 miles apart, and never bump into 1 another,, ... its just my mate was gonna get a 50cc, better on a 125 eh,,,
  8. Welcome ted,, , your near Drewpy, , fill in your profile, helps with info etc,
  9. Aye guys" a mate thinkn of a 50cc , i told him get a 125, ,whats the figuers, he had a TS125 in 1980 . . he needs it for fishing trips,,
  10. Yeh great intro joe" bmx riders will find motorcycles easy, once used to the weight, you"d be at home on a trial bike,light and great traction,,,
  11. Mmmm must check the TS250, first reg,1974,,,, dunno about manufacturing date,,,
  12. He is dam right matt, every word,,,
  13. Best with the 300 tdi newman" or the 200, they burn cooking oil,,[ summer] mines is near 300,000 mlies,, engine never had a spanner near it, ...only Altinator, starter,
  14. Perfect intro Scott, --- . .
  15. New plug " had this at stafford show, [gsx] ran- swiched off , took bike outside. wouldn"t start. tried bumping , it offered, pulled plugs, wet" stuck in new plugs, boom fired,,
  16. Welcome rick,, the RD engines are simple , horizontal split cases, turn upside down on bench, whip of bottom case, everythin is in line ,Crank- input shaft- output shaft- kickshaft,, all lift out complete. leaves selector drum in top case,,,
  17. How did this happen grouch"o , lack of oil is about the only way to fuck a box,,, i bet the selector pawl is worn or the return spring weak, its on the outside of box, behind the clutch cover,,,
  18. Welcome steve " as he says,,,,
  19. Am outside till it dark at this time of year,, unless its raining ,,,
  20. 1978 YZ 100 ---2K5 ....1978 YZ125-- 2K6 ... cant find 2K4 on my list,,,,,
  21. Welcome mark" should get calipers fo it on fleabay,,,,, failing that other models will fit ,, might need to make adaptor plates
  22. Just go easy on it , no redline bursts , for a couple of hundred miles . , mind your on new tyres , watch the first couple of miles, as ther covered in releasing agent. off the moulds,,,
  23. As he says matt, tell em about forums etc,,,, Did you not try Breaking point in aberdeen,,
  24. Was ther not a split link on the cam chain,,, so it could be removed after the head was off,
  25. welcome G.dog" slip it off . and turn it down a spline, simples....
