blackhat250
  1. Hi phill" Another YB Owner,,,Ebay thailand and singapore, have N.OS parts,,
  2. Free Waterproofer,,,, you must ride behind my triple again,, for a recoating,,
  3. blackhat250 replied to NEV's topic in Yamabyss
    That be a back tyre chewer that,,,, Very fast.... almost as fast as a ZZR14 ... ninja A mate had a busa , he says your vision is blurred when flat out,,,,
  4. Bloody ell lads ,you"l be on for the farthest Travelled rosette this year, mind set the trip. meter,, i might ride the 250 down, we"l see what weathers like that weekend,,
  5. Hi jr" good to see you back on bikes , post up pictures ,and a question in workshop area,,
  6. phew 2 cudda been nasty, tighten up all bolts etc,,after your shake down,, i"v been there , front sprocket nut fell off ,
  7. I think its a 1974 - as the later engines are 393-00001 is GT80A To GT80C - 393-25101
  8. That does go with the black rims,
  9. Hi jo" we [ triples boys] ride to South Queens ferry often in summer,, , . good choice the XJ, .Just don" let wild foamy know what the N stands for, And Cynic " get lost ,,
  10. Hey presto....http://www.ebay.co.uk/itm/YAMAHA-RXS100-RX100-RXS-RX-FULL-ENGINE-OIL-SEAL-KIT-/220868159097?pt=UK_Motorcycle_Parts_13&hash=item336cc4a679 Or =http://www.ebay.co.uk/itm/RXS100-output-shaft-seal-RSX100-drive-shaft-oil-seal-FAST-POST-/350507772124?pt=UK_Motorcycle_Parts_13&hash=item519be428dc
  11. Abby tuning" All good,,,
  12. Yami Mad, has been A.W.O.L since 2/5/2009.....
  13. Welcome dan" gotta be some nice bits at the dales, but legal is the thing ,,,
  14. Great journey " cute wee bike, now there were new seats still for sale on ebay thailand . lots of Yb"s sold overseas .
  15. Hi Winston" The carbs be the first thin to pull of her,, check out felix"s post in projects,, hes just restored a FZ600 gives you ideas
  16. Do you have a manual ? setting are there, to set correctly , you need a strobe light . and run at 4000 rpm, to see marks line up.
  17. Right , the B/White wire only grounds the spark,[ fault must be on kill switch or ignition] = lights will work, Your poor running - could be High altitude, [ lack of air - poor mixture] = drop the needle a clip. smaller pilot maybe. The pump [oil] you"ve bled it, now when bikes on idle , pull the pump cable to full open [ not throttle cable] till oil rises to carb, [ clear hose to see this ]
  18. Hi nick" like the expansion pipe ,,,,
  19. Probably copy"s,,, canna see 4 failing tho.. did you fire it up then,,,shudda pre-mixed a little fuel . i hold the pump wide open by pulling the pump cable [ while on idle] till i see oil up to carb...
  20. Yeh neil " ram air pod on pipe he means,,, the pilot jet removes , you need a small flat blade driver [good quality] thers a post on here with video on carb service,,
  21. Ok " [On DT models] White - runs from Mag to one side of silcone Rectifier, the red off other side of rect = battery, via a fuse,,,, On the [RT Models] . White go"s from ignition switch - to rectifier . and red off other side to battery,,
  22. On the road ready for Squires.... The 2 -250"s from the 70"s
  23. Welcome fish4E" will look at my diagrams soon... .
