blackhat250
  1. Hi habbie,,, wheres about ae you based,,,east or west,,
  2. Hi freeamp" get some pics up of the XJ
  3. Well done bobby" all this info will help others in the future, ,, thats the beauty of forums , [shared info.]
  4. What kinda bike " not the YZ125 is it,,,
  5. No Jaun Mata gotta be worse..
  6. Hi drew " every day is a learning day,, would be boring if it wasn"t
  7. Thats an expert assumption Andre,,, .... its the cause...
  8. blackhat250 replied to rjh357's topic in Classics
    Class reply....
  9. Yip the backfire is excess fuel, Pull the carb,, check its jetted to manual spec,,Carb-mikuni VM34. Mainjet 190 -pilot-80. check the reeds too , there old now ,,pull the reed block and inspect,
  10. Yes bobby, remove the flywheel and stator plate for L/H side. and clutch and primary gear to see the R/H ,
  11. Runs on half choke ? then its lean, is there a air filtre on her,,, screw air/ pilot screw in,,a half turn,
  12. Aye jimmy, if you needed money , you cudda been on oil supply vessel or the like, be happy ,,,
  13. Hi there , thers a few Xs fans in here ,with a wealth of knowlege ..
  14. Ok " do a compression test, next,,,
  15. Hi Chappy" is it welded to the shaft,? or is it the stem thats broke,,, picys needed,
  16. Hi drew , spit back usually means the inlet valve aint closed proper, check timing and valve clearance.. how many miles on her ?
  17. You"l need a meter. find Yellow/white , from generator , it goes to headlight , then diode rectifier, then battery,
  18. Ok , the java link , said i have the current edition, and uninstalled old versions,,, am wary of downloads , as the open gate for pop up ads etc,,,
  19. The way you ride it Kristian, youy"ve killed 2 top ends, and the big bore kit will not be as robust as factory spec, i would buy a bigger bike, as then it will not be flat out most of its life,,,
  20. Chainguard too far back,,,,
  21. Good progress Mac, great that the wiring is complete
  22. I think once you go over chain size 520 you only get a rivit link suplied . a mate says " big horsepower bikes should have rivit link ,
  23. Hi james , thers a few posts on TZR125"s in the workshop area,, do a search,,,
  24. On login , a banner apears , Java plug in is need to run this site ,, Whats the story ,,, Spam ,,,,,,,,
