blackhat250
  1. What did that mean then,,,,
  2. Hi daz,,, , the good old XS250 . they were a peach , ask jimmy,,,
  3. burning oil you mean,, ,,how often are you checking level,,,doe she smoke,,,,
  4. Hi ed " thats some cute old steeds there,,,
  5. Sounds like low on compression,, starts cold- not when hot... = valves burnt or worn rings,,
  6. Aye "shes ready to rock ritchie, looks a bit like the old GPZ750 ,,
  7. Hi B.B. " Its fuel starvation anyway,, as the choke is supplimenting a choked pilot jet , or low float level, or fuel filtre blockage,/ Start a new thread in workshop , as this could run on, and this is the newbee section ,,
  8. Is it just compression your going thru,,,,[ cycles]
  9. Ok jonny" that floatvalve may be leaking , [ no amount of height setting will stop fuel leak,] or DO them floats actually float,, . check them . carb boot needs fixing , it will be lean if air pulls thru it, ,,,get back when all these are fixed ,, Here was mine in 2010
  10. Thats like clut ch slip...
  11. Rectifier/regulator, you need to check whats coming in [ volts] multi meter needed.
  12. Good you noticed . woulda been a disaster on long ride away from home,,
  13. , where airhead,,,,,,,,,,,,,,,,,,,,
  14. Hi danny " the Wr is all good , even the 250..
  15. Yeh cosmetic changes till 1978 , then the Mono shock appeared,,, get stuck in , if you need advise , post up here ,,,
  16. Good intro carson, lots of help in here,,
  17. Yeh resto"s can run up the bills, turn signals are cheap, ,,, did you change the rear yoursell " it been hard as hell
  18. Thats very tidy " rim tapes set her off ,
  19. blackhat250 replied to mailee's topic in General
    Well done mailee "
  20. Hi zulu " go to the page in manual that covers fluids & read it,,,the oil tank will be 2stroke tank ,, fill with semi-synth 2T,, you wont need pre-mix , unless tank -pump have been disconected..
  21. Hi carson " take out the spark plug , and watch for a spark when working them switches,, also pull the carb off, bound to be crud in there, u tube has carb clean demo "s... Also nip up to the new members section and do an intro,,,
  22. Great pics,,, that be the RD400C in the marine /turquoise blue,,, nice,,,
  23. Hi wayne " i think its coz his dad had a James of 1950"s erra --?
  24. Job done.....glad you reported back,,,as 1 hitters just disappear ,,,
  25. Get the drop down box on ph/bucket of picture, select get links, another BIG box appears -click on IMG ,,, should flash Copied
