blackhat250
  1. Aye slicer " it will run lean as hell , it will need choke on startup for a lot longer than normal, then thers the flat spot when given a big hand full,. The jetting will be a nightmare to get correct, if them guys have the proper kit sounds good , as you"l spend a lot of time and heart-ache setting her up, [ as they have ,to got where they are with the kit] Am a stock airbox fan,,
  2. Aye Elliot" I think it be 1 down & 4 up with neutral between 1st& 2nd, as in most RD"s
  3. blackhat250 replied to s900t8v's topic in Projects
    What tools are you using to file out ports and reed intake ?
  4. blackhat250 replied to s900t8v's topic in Projects
    Yeh " are them cushion rings just to stop chatter,[ noise] . , some triples boys bead blast the steels, for more friction,,, Back up to the reeds, you say you may enlarge the openings on the cage,,,will the reeds still cover, are they plenty big.[overlap]?
  5. Beinvenida senor " Enjoy the forum,,,,
  6. " --- -------
  7. blackhat250 replied to ianf7771's topic in The Bar
    Aye ian , surf Ebay -thialand , is amazing what still out there, N.O.S too,
  8. I suppose its an unmeasured answer this,,,if gentle riding I think probably the life of the bike, I burnt out the clutch of my DT175 in 1977 . in 1 ploughed field ,got bogged and had to slip clutch to get out,, fried and knackerd completely,,
  9. I remember this,,,you gotta laff @ ,,,,on day release from the mental hospital.
  10. blackhat250 replied to s900t8v's topic in Projects
    Sounds interesting " how you gonna mate the bigger carb,? and the filter side will be 50mm at least, you gonna fit a pod, filter, .? With them reeds you removed the buffers, does that work ok,,,
  11. Yeh that's the good thing about these threads, . informs others A year + half " has got to be a record for a reply tho,,
  12. blackhat250 replied to s900t8v's topic in Projects
    This a great read " very interesting ,, I"v always been wary of porting, but you"ve got it sussed, it same old story tho with the clutch, you get more power and she lets go,,,thers a yank company Redline , they do clutch mods, triples boys use them,
  13. Welcome Marioc " a few pictures of YA 6 wuld be nice,,
  14. Yeh " give her a good blast mallit, she should run clean after a few miles,
  15. Good find drewps " bit normal for your taste
  16. Welcome in benda" you have to sit the test in ausieland,?
  17. Hi there" was this show at NEC Birmingham last year, ? I thought it was trade only, .
  18. Yes " DT"s are simple engineering,, when you take the plates off , hang them on summat [ in order they come off] , and install them in the correct order,
  19. Enjoy the nervousness " its them feelings that make you feel alive,,,
  20. Hey Oj " threy"re the same the world over, ,, a few dicks the exception [ usually the white boot brigade]....
  21. Search your end for an item like this,, http://www.ebay.co.uk/itm/Universal-Flywheel-Puller-Tool-6-Sizes-10-14-16-18-24-27-Motorcycle-Tools-/250992924785?pt=LH_DefaultDomain_3&hash=item3a70581871
  22. Hi mallet " the Zed is a heavy beast , hows the DT coming on,,?
  23. Yeh oj" I use a lot of back brake in wet or gravely roads, easier to control if she slides,,
