Everything posted by jeepurz
New Member, Old Bikes
welcome and looks like a fun project, not alot of em around anymore, Im gonna make some popcorn and watch this playout. good luck ; Jeep.
XS650 in a XS360 Frame
unless youve got an unlimited budget and a lot of skills id say nope , or why? xs650's are easy and cheap enough to find, youd be better off finding one and redoing it.
xs650 special
If you can lay your hands on a cb 500 T tank 1975 its a good fit and good look for a cafe, ive also seen the 750 tripple yamy standard on several . 500T tank in pic. on a 76 xs standard.
Compression Release on DT 125???
back then they had a two plug head, comp release was aftermarket back in the day the compp release screwed in to second plug hole. , sort of a jake brake for bikes in theory.
fork seal install
heres some pics, I circled one gouge in marker, I also wrote #'s marked on leg. my cal batterys dead so I stuck a tape on em but im purty sure there 34. If you can use em ill just swap you straight up, I make headlight shrouds out of them and the broken part on yours wont effect what im doing with them, take the pair or single side either way. check the pics close to be sure. 1st pic left side is jap. writing (symbol) between fender mount. .
fork seal install
Ok think ive got a set, do you have pic of yours, 75 and 76 are dif I think , these were off 76, they use same cal but one is behind fork and one is in front of leg. Ill try to take a pic.
fork seal install
where you located, Ill dig around , those are 34's might be a little harder to find, but I may have a set. Ive used a socket to drift them in .
I think I am turning Cafe, I really think so
try this info on the carbs http://xs650temp.proboards29.com/index.cgi...mp;thread=10402
steel shot in the bars, yes emco's do block Ajet, you can prob notch around it, but ebay under powersports has gocart filters that are exact copys of K&N's at around 24.00 per pair, No brace should be needed on filtercarbs. Sorry no help on carbs, ive ebayed the stockers and opted for roundslides, you might check with 650 central and send mike mercury morries an email on your carbs the guys a whiz.
i need to remove a rounded nut
dremall moto tool with a cut off wheel works great , cut a slot and use an impact.
1973 or 1974 enduro 125
ebay store seller , mrssuperdeals, purty good selection of stuff , very good service and sales.
XS 650 UK Based Spares Suppliers
did they sell a heritage special over there??
- 2008 in pictures
XS 650 B
looks like a good donor, check your valve clearance, timing , carbs,, bout 1st. toss that elec as far as you can, tuned right itll start right, and without elec youll keep it tuned right. not sure where your located but if you need frame help yell.prob point you somewhere in the us or uk.
Ultra Sonic Carb Cleaning
dissassemble carbs pour common lemon juice in pan, put in carbs, bring to simmer 5min., dont drink lemon juice, & carbs will look new. it works . got this tip from a buddy in canada so those long winters are good for something! .
stupid or just stupid
Id bet that guy couldnt buy a peice of ass in a cathouse.
- 1976 YZ 125c CDI unit.
if im understanding you right, is the magent holding it in place, they do tend to grab things, I cleaned points on an mr 175 honda, I removed the bolt and pulled flywheel, after it popped it still was a two handed job sliding it out. JMO. By jeepurz- bike has no spark
start simple with fuse, then connections, worse comes to worse itll be tci box. was it a runner before ?- cool story, cool bike
those cats in the netherlands turn out some awsome garage builds, this guy took it a step further, "road trip" http://www.nimbustripinjapan.blogspot.com/- hitler strikes again
gezz I thought he only got pissed when he drank whiskey!! but I can relate , if youve got vista on a HP youve got a thousand dollar DVD player without sound.- 1973 RT3 360
try here , he may have diag. http://www.bikechatforums.com/viewtopic.ph...asc&start=0- XS650 CDI kit work on TX/XS500?
get a ahold of pete, ask him he's great on fitments , im using his VR291 along with two radio shack rectifiers on my xs, a system he designed. the guys real helpfull. http://www.yamahaxs650.com/- Reg/Rec unit testing
try this http://www.electrosport.com/technical-reso...osis-center.php- Exhaust header wrap
none what so ever , ive wrapped pipes for years. (wear gloves when wrapping). - 1976 YZ 125c CDI unit.
