Everything posted by Ferg
One Cylinder Back Fire
- HAPPY NEW YEAR
Happy New Year from all down in OZ.- Bolt sizes
I may be wrong here but dosn't the brake lines go into the bottom of the caliper?? If it does you will not be able to bleed the air out as it is at the top of the caliper.- Whats this for ?? - XT350
It may be from a TT 350. I think the breather on them went into a tee piece. Hope this helps. Cheers Ferg.- Help Identify 2K9 Yamaha
G,day. According to this site ( http://www.merrittmotorcyclesalvage.com/yamahamodelcodes.htm ) it is a 1978 it250e. But with this site ( http://www.cmsnl.com/faq.php?fq_catid=15 ) it would be a 1978 yz400e. Hope this helps. Cheers Ferg- Headlight replacement '88 xv250?
try this site. http://www.bsy.com/pages/parts/viewbybrand/2/Yamaha.aspx cheers Ferg- Vin Number
Could be a 1992 model. Check here http://www.motorsloop.com/index.php?main_p...roducts_id=2383 Cheers Ferg- To the Gixxer rider.....
If its too upsetting for you then stop bloody mentioning it in every other post you make!!!!!! Anyway - this is a bike site not a damned dog site so back to bikes now if you please. here here- XT 350 electrical
G,day. Is the battery only hot when the bike is running? This would probably mean a faulty regulator. The headlight and tail light will only work when the bike is running. The bike does not have to be running for the brake light ,blinkers or horn to work. The brake light problem could be a broken wire in the loom near the head stem where the loom moves when turning but you need to rule out all other possibilities (globe ,connections ,switch etc)before pulling the loom apart. I have a service guide for the 85 xt 350 that has a wiring diagram. Just send me a PM with your email address and I can send it to you. Cheers Ferg- TT600 wants to run when it wants to
G,day Death star. You said that it has not run since you put the ebay sourced cdi box on. What happens if you put the old cdi on? Cheers Ferg- TT600R
G,day Mick. I'm from Holbrook and have a '95 tt600. Great bikes. Anyway PM if you want to chat. Cheers Ferg- Clutch won't disengage!!!
G,day notmuchair. Did the clutch disengage before you replaced the cable?? If it did then the problem is not inside. Is the lever on top of the clutch facing the right way(not out 180 degrees)??? Cheers Ferg- SERIOUSLY SLOW XT125 PROBEM
Fitting a smaller front sprocket????? You must want to go even slower.- 1965 YDS5 Clutch problems
G,day Brian. Try this company in florida. http://www.bsy.com/ When trying to search for parts you will have to put it in as a 1967 model. Cheers and good luck Ferg- '75 XS500 only one cylinder firing
leave us aussies alone- xs 360 runs on right cylinder only
How about swapping your right/left coils and see if the problem changes sides. Cheers Ferg- Oil And Plugs!
G,day Adam. Just wondering about synthetic oil in a '95 tt 600 s Belgarda.Although this is a dry sump will it also make the clutch slip?? Thanks Ferg- BAN ALL BIKES!!!!!!!!
After reading about harley's in this forum i realised why this fellow wants to ban motorcycles. He had his cock stuck in the exhaust pipe of a harley Thats the name i left on the petition also.- Finding an old part
G,day. I believe the relay you are talking about also includes the relay for the starting system.It has the same part number as the one for my fj1100.Maybe if you had a wiring diagram you could seperate the two. The following link is to a parts warehouse and it shows all the models that use that relay. http://yamaha.partswarehouse.com/pages/parts/default.aspx Just type in the part number (41r-83350-71) in the quick find section . Hope this helps. Cheers Ferg- little pw 50
I just saw this old posting and I could show you how to bypass the off-run-start switch if you like. Cheers Ferg :- What Year?
It could be a '97 model. Go to the following website and scroll down the FAQ's. It shows yamaha's year model prefix. https://www.yamaha-motor.com.au/ssl/index.htm?motor_faq.asp Cheers Ferg - HAPPY NEW YEAR
